MannyLemon 1 Posted November 7, 2025 Posted November 7, 2025 Same issue here. We found the file but we aren't quite sure what to replace the text with
Luke 42239 Posted November 7, 2025 Posted November 7, 2025 @MannyLemonHI there, what issue are you having? What file did you find?
Solution MannyLemon 1 Posted November 7, 2025 Author Solution Posted November 7, 2025 We found the xml file and got rid of the ip address under the localaddress column. It worked, thanks 1
