scegg 12 Posted November 7, 2025 Posted November 7, 2025 Emby: 4.9.1.80 in docker x64 Issue: for all video files in MKV format, when built-in thumbnail is saved in image/webp format, Emby won't read it.
Luke 42288 Posted November 7, 2025 Posted November 7, 2025 Hi there, what makes you think Emby won't read it?
scegg 12 Posted November 8, 2025 Author Posted November 8, 2025 8 hours ago, Luke said: Hi there, what makes you think Emby won't read it? Emby generates and shows a snapshot of this video instead of the embedded cover as icon.
Luke 42288 Posted November 13, 2025 Posted November 13, 2025 What does the media info show at the bottom of the web app detail screen?
scegg 12 Posted November 13, 2025 Author Posted November 13, 2025 1 hour ago, Luke said: What does the media info show at the bottom of the web app detail screen?
scegg 12 Posted November 13, 2025 Author Posted November 13, 2025 This file was generated by yt-dlp from youtube.
scegg 12 Posted November 13, 2025 Author Posted November 13, 2025 2 minutes ago, Luke said: OK we'll take a look at it. Thanks. I can attach a smaller file generated from a shorter youtube video for testing. 1
Luke 42288 Posted November 13, 2025 Posted November 13, 2025 3 minutes ago, scegg said: I can attach a smaller file generated from a shorter youtube video for testing. I've found the issue, thanks.
