MiCo1972 6 Posted November 5, 2025 Posted November 5, 2025 I am unable to control the Emby app for Windows via iPad or web browser. Although I can see which film is currently playing, I cannot pause it or start a new one, for example. It works on the same computer with Emby Theatre. kindly regards Michael
Luke 42232 Posted November 5, 2025 Posted November 5, 2025 Hi there, what exactly happens when you try?
MiCo1972 6 Posted November 5, 2025 Author Posted November 5, 2025 Hi, exactly nothing happens. No error oder such a thing, nothing.
Luke 42232 Posted November 5, 2025 Posted November 5, 2025 Hi there, please attach the Emby server log from when the problem occurred: How to Report a Problem Thanks!
MiCo1972 6 Posted November 5, 2025 Author Posted November 5, 2025 Here is the log. I hope you can find the problem. Thanks a lot… greetings Michael embyserver.txt
Luke 42232 Posted November 5, 2025 Posted November 5, 2025 55 minutes ago, MiCo1972 said: Here is the log. I hope you can find the problem. Thanks a lot… greetings Michael embyserver.txt 64.32 kB · 0 downloads Hi, what exactly did you try to do during this time?
MiCo1972 6 Posted November 5, 2025 Author Posted November 5, 2025 I restarted the server once so that the log wouldn't be too long. Then I tried to start a film on the Windows computer running the Emby app via the server's web interface. That didn't work. I saved the log immediately afterwards. So these should be the last entries. Best regards, Michael
Luke 42232 Posted November 5, 2025 Posted November 5, 2025 Quote Then I tried to start a film on the Windows computer running the Emby app via the server's web interface. What are the steps that you took to do this?
MiCo1972 6 Posted November 5, 2025 Author Posted November 5, 2025 In the web portal, I click on the "Play on another device" icon in the top right-hand corner and select my computer, which also appears there. Then I click on "Play" for a film, but nothing happens. If I start Emby Theatre on my computer instead of the Emby app and do the same thing, it works. Kind regards, Michael
MiCo1972 6 Posted November 13, 2025 Author Posted November 13, 2025 Hey, is there perhaps a solution to my problem, or is it due to the new app? Kind regards, Michael
MiCo1972 6 Posted November 26, 2025 Author Posted November 26, 2025 Hello Luke, is there anything else I can do to speed up the resolution of this issue? kindly regards Michael
Luke 42232 Posted February 5 Posted February 5 Hi, we'll have a new update to Emby for Windows out soon. Please let us know if that helps once you have it. Thanks !
MiCo1972 6 Posted February 5 Author Posted February 5 Hi Luke, thanks a lot. I will try it. Greetings Michael 1
MiCo1972 6 Posted February 15 Author Posted February 15 I have tried the beta and it works fine. Very nice! If the app could now remember that I always want dynamic adjustment of the aspect ratio, it would be nearly perfect for me. Many thanks! Best regards Michael 1
