Caliber 0 Posted November 2, 2025 Posted November 2, 2025 Hello emby, I can't seem to get emby to work running linux mint. I heard good things about emby so thought I would try it out instead of watching my movies from my computer plugged into my tv to view my movies I could watch them from my android tv with the movie posters. I have emby installed but when I try adding my movies to my external hard drive it's nowhere to be found even though my hard drive 8tb shows on my desktop I'm confused. I have about 40 movie backups and thought this might be a good new way to watch my media if it works thanks.
Luke 42242 Posted November 2, 2025 Posted November 2, 2025 Hi, what exactly do you need by nowhere to be found?
Caliber 0 Posted November 2, 2025 Author Posted November 2, 2025 I can't add my movies into emby from my hard drive I can't see it to add my movies.
sargenthp 35 Posted November 2, 2025 Posted November 2, 2025 Make sure the emby group has access to read the files.
Caliber 0 Posted November 2, 2025 Author Posted November 2, 2025 Sorry but I'm not sure how I can do that I only started using linux a couple months ago, thanks for the suggestion if you can tell me how.
Caliber 0 Posted November 2, 2025 Author Posted November 2, 2025 Lol this is confusing maybe it's not for me.
Caliber 0 Posted November 2, 2025 Author Posted November 2, 2025 Funny I tried on a windows laptop it worked right away with my hard drive plugged in but I plan on installing linux on my laptop tomorrow I like linux way better. If anyone has the knowledge to get this working let me no thank you.
Caliber 0 Posted November 2, 2025 Author Posted November 2, 2025 Luke is there a linux operating system that you know how to use ? I could install a different one that you can understand if it works easy for you to help ? Let me know if you understand how to get emby running on linux or not. Thank you Luke. If you don't know how please let me know.
Caliber 0 Posted November 2, 2025 Author Posted November 2, 2025 I'm on distrowatch now, on windows distrowatch is blocked it says ERROR but on linux it works because microsoft blocks distrowatch website. I will download MXlinux next and install it to see if emby works with it.
Caliber 0 Posted November 2, 2025 Author Posted November 2, 2025 What if I install ubuntu server on one pc then login with another and plug my hard drive into the ubuntu server would that work with emby ?
MediaEmby1968 54 Posted November 2, 2025 Posted November 2, 2025 If you're not familiar with Linux, give it some time. Linux Mint is a good option. And MX Linux is also good, with the XFCE desktop environment, which uses fewer resources. What you need to do is create a folder to mount that 8TB hard drive. I also use an external drive. By default, I think it mounts to /media, but it's better to use /mnt. You can mount it graphically with the GNOME Disk Utility application. Once mounted, you grant it permissions and you'll be able to see the folders.
Caliber 0 Posted November 2, 2025 Author Posted November 2, 2025 (edited) I will try maybe freebsd Edited November 2, 2025 by Caliber
Caliber 0 Posted November 2, 2025 Author Posted November 2, 2025 3 minutes ago, MediaEmby1968 said: If you're not familiar with Linux, give it some time. Linux Mint is a good option. And MX Linux is also good, with the XFCE desktop environment, which uses fewer resources. What you need to do is create a folder to mount that 8TB hard drive. I also use an external drive. By default, I think it mounts to /media, but it's better to use /mnt. You can mount it graphically with the GNOME Disk Utility application. Once mounted, you grant it permissions and you'll be able to see the folders. Hey bro, GNOME Disk Utility application I will look for it thank you buddy. I will let you know how I make out.
MediaEmby1968 54 Posted November 2, 2025 Posted November 2, 2025 Check if it's already installed; it's called Disks and should appear in Utilities, I think.
Caliber 0 Posted November 2, 2025 Author Posted November 2, 2025 so mount the mb 210 fat the other one says unmount i plugged in a 26tb
Caliber 0 Posted November 2, 2025 Author Posted November 2, 2025 it shows 2 it shows the 210mb and the other beside it says 26tb exfat
MediaEmby1968 54 Posted November 2, 2025 Posted November 2, 2025 Here I leave you a video so you can see how to assemble it, even if it puts plex, it is the same, it will serve you the same as it did for me in its day. https://www.youtube.com/watch?v=of9gAXtoQKI
Caliber 0 Posted November 2, 2025 Author Posted November 2, 2025 theres ike a play button under it says mount 210mb partition ? could it be that easy ?
MediaEmby1968 54 Posted November 2, 2025 Posted November 2, 2025 I'm going to sleep, I'll read to you tomorrow.
MediaEmby1968 54 Posted November 2, 2025 Posted November 2, 2025 Notice that on the left side you'll see the drives you have mounted. You need to connect the external drive and change the mount point. Don't touch that 210MB one... without seeing it... I'd say it's the UEFI partition. First, watch the video and find out how to use that program to mount disk drives.
sargenthp 35 Posted November 3, 2025 Posted November 3, 2025 14 hours ago, Caliber said: I will try maybe freebsd Permissions are going to work the same on all UNIX like OS's. Linux will have better support and more drivers.
sargenthp 35 Posted November 3, 2025 Posted November 3, 2025 Please copy and post the output for the following commands at the command line... lsblk df 1
Caliber 0 Posted November 7, 2025 Author Posted November 7, 2025 (edited) debian@Debian:~$ lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS sda 8:0 0 119.2G 0 disk ├─sda1 8:1 0 976M 0 part /boot/efi ├─sda2 8:2 0 112.5G 0 part / └─sda3 8:3 0 5.8G 0 part [SWAP] sdb 8:16 0 23.6T 0 disk ├─sdb1 8:17 0 200M 0 part └─sdb2 8:18 0 23.6T 0 part /media/debian/USB debian@Debian:~$ Edited November 7, 2025 by Caliber
Caliber 0 Posted November 7, 2025 Author Posted November 7, 2025 I have tried over 15 linux distros and I like debian 13 the best I'm keeping debian as my main OS on all my computers from now on it looks and feels the best out of every OS I ever used. So if I can get emby running on this great if not that's also ok. Thank you for helping!
