Darren & Gemma 12 Posted November 2, 2025 Posted November 2, 2025 Hi. I've been using the Smartthings integration for some time, configured to dimthe lights etc when I start movies after a certain time. This appears to have stopped, and upon checking the plugin details, its lost its configuration for the device profile. I configured it again, it works straight away, and then the following day, its lost its settings again. Is this a know issue or has anyone else experienced this? Thanks
Luke 42239 Posted November 2, 2025 Posted November 2, 2025 Quote Hi. I've been using the Smartthings integration Hi, where exactly is this?
Darren & Gemma 12 Posted November 2, 2025 Author Posted November 2, 2025 11 minutes ago, Luke said: Hi, where exactly is this? This dropdown menu in the profile configured is where it pulls through the routines in Smartthings. I set these and save it, it works. The next day its blank and doesn't work
Luke 42239 Posted November 3, 2025 Posted November 3, 2025 OK, I think @chefis the developer and he'll need to comment on this. Thanks.
Darren & Gemma 12 Posted November 3, 2025 Author Posted November 3, 2025 24 minutes ago, Luke said: OK, I think @chefis the developer and he'll need to comment on this. Thanks. Ok thanks @Luke. @chef- Can you help?
Darren & Gemma 12 Posted November 8, 2025 Author Posted November 8, 2025 @chefis this something you can help with??
Luke 42239 Posted November 11, 2025 Posted November 11, 2025 I would try sending him a PM in the event that he doesn't see this.
