Nastream 5 Posted October 28, 2025 Posted October 28, 2025 Hi everyone, I’m new to Emby Premiere and currently running version 4.9.2.6 beta. I’ve just installed M3UTuner (v1.0.41.0) — it works, but I’m noticing very slow channel startup and channel switching. I also tried using HDHomeRun, but the same issue occurs — channel changes take several seconds. With Tivimate, however, everything loads instantly, so it doesn’t seem to be a network or source issue. Has anyone else experienced this? Any suggestions or settings I could try to improve performance? Thanks in advance for your help!
denz 501 Posted October 28, 2025 Posted October 28, 2025 (edited) We all experience this and we have been waiting since Emby was released to be improved and we are still waiting Edited October 28, 2025 by denz
Luke 42239 Posted October 28, 2025 Posted October 28, 2025 8 hours ago, Nastream said: Hi everyone, I’m new to Emby Premiere and currently running version 4.9.2.6 beta. I’ve just installed M3UTuner (v1.0.41.0) — it works, but I’m noticing very slow channel startup and channel switching. I also tried using HDHomeRun, but the same issue occurs — channel changes take several seconds. With Tivimate, however, everything loads instantly, so it doesn’t seem to be a network or source issue. Has anyone else experienced this? Any suggestions or settings I could try to improve performance? Thanks in advance for your help! Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
Nastream 5 Posted October 29, 2025 Author Posted October 29, 2025 Hello @Luc here is an example embyserver.txt
Nastream 5 Posted October 29, 2025 Author Posted October 29, 2025 I have the impression that it triggers some kind of transcoding — maybe that’s what’s slowing down the channel loading and zapping.
Luke 42239 Posted October 29, 2025 Posted October 29, 2025 2 hours ago, Nastream said: I have the impression that it triggers some kind of transcoding — maybe that’s what’s slowing down the channel loading and zapping. Hi, yes when there is transcoding it will cause the channels to take slightly longer to start.
stplatt 9 Posted October 29, 2025 Posted October 29, 2025 3 hours ago, Nastream said: I have the impression that it triggers some kind of transcoding — maybe that’s what’s slowing down the channel loading and zapping. I think regardless of transcoding emby does some probing of the stream before playing it to determine whether transcoding is necessary. This results in some delay in playback 1
Nastream 5 Posted October 29, 2025 Author Posted October 29, 2025 Yes, but the problem is the same, even without transcoding.
denz 501 Posted October 30, 2025 Posted October 30, 2025 We we’re teased about faster tv channel change but it is abandoned you can read about it here
Nastream 5 Posted October 30, 2025 Author Posted October 30, 2025 ah yes it’s a real topic that dates back several years, I don’t understand why it’s blocking when it’s one of the reasons that drives us to take a subscription first
