supersaugi 9 Posted October 28, 2025 Posted October 28, 2025 hallo hab immer noch das Problem z.b aber im Filmordner ist nur
Luke 42239 Posted October 28, 2025 Posted October 28, 2025 Hi, what is the problem? They are in the server's metadata folder.
supersaugi 9 Posted October 29, 2025 Author Posted October 29, 2025 Thanks. I thought they would all be saved in the movie folder, as clicked before scraping.
Luke 42239 Posted October 29, 2025 Posted October 29, 2025 In the library options, did you enable saving images to media folders?
GrimReaper 4895 Posted October 29, 2025 Posted October 29, 2025 Maybe there are permission issues preventing saving to media folders - refresh an item and post server log. How to Report a Problem
Luke 42239 Posted October 29, 2025 Posted October 29, 2025 Or rather, try using the image editor to download a new image manually, and then provide the server log after that. Thanks.
supersaugi 9 Posted October 29, 2025 Author Posted October 29, 2025 hier ein Auszug wie es ausschaut liegt es wohl an mir das er nicht in die Ornder schreiben kann Quote 2025-10-29 20:47:25.726 Info ProviderManager: Saving image to smb://192.168.178.34/Filme/Filme/Ein unmoralisches Angebot (1993)/poster.jpg 2025-10-29 20:47:25.885 Error ProviderManager: Error saving to smb://192.168.178.34/Filme/Filme/Flashdance (1983)/poster.jpg. Failed to write to file. 2025-10-29 20:47:25.885 Info ProviderManager: Saving image to /var/lib/emby/metadata/library/19/19052feaa56133e9e564ebd26b9f1091/poster.jpg 2025-10-29 20:47:25.914 Info HttpClient: GET https://image.tmdb.org/t/p/original/mi51S3wE9OHcclUS86HxfkWW8Wd.jpg 2025-10-29 20:47:25.948 Info HttpClient: Http response 200 from https://image.tmdb.org/t/p/original/mi51S3wE9OHcclUS86HxfkWW8Wd.jpg after 34ms 2025-10-29 20:47:26.010 Info ProviderManager: Saving image to smb://192.168.178.34/Filme/Filme/Zärtliche Cousinen (1980)/poster.jpg 2025-10-29 20:47:26.136 Error ProviderManager: Error saving to smb://192.168.178.34/Filme/Filme/Fifty Shades of Grey - Gefährliche Liebe (2017)/poster.jpg. Failed to write to file. 2025-10-29 20:47:26.136 Info ProviderManager: Saving image to /var/lib/emby/metadata/library/fa/fab9b11e3cb2757002332f59a4b18313/poster.jpg 2025-10-29 20:47:26.264 Error ProviderManager: Error saving to smb://192.168.178.34/Filme/Filme/Bodyguard (1992)/poster.jpg. Failed to write to file. 2025-10-29 20:47:26.264 Info ProviderManager: Saving image to /var/lib/emby/metadata/library/be/be2d8d43671f17b3ed02e0eba955a72f/poster.jpg 2025-10-29 20:47:26.307 Error ProviderManager: Error saving to smb://192.168.178.34/Filme/Filme/Eiskalte Engel (1999)/poster.jpg. Failed to write to file. 2025-10-29 20:47:26.307 Info ProviderManager: Saving image to /var/lib/emby/metadata/library/a7/a74d91e20e167ad62ca9445716fba06e/poster.jpg 2025-10-29 20:47:26.353 Error ProviderManager: Error saving to smb://192.168.178.34/Filme/Filme/Priscilla (2023)/poster.jpg. Failed to write to file. 2025-10-29 20:47:26.353 Info ProviderManager: Saving image to /var/lib/emby/metadata/library/a1/a186ea2d9aa2915221971f509fc7e617/poster.jpg 2025-10-29 20:47:27.108 Error ProviderManager: Error saving to smb://192.168.178.34/Filme/Filme/Ein unmoralisches Angebot (1993)/poster.jpg. Failed to write to file. 2025-10-29 20:47:27.109 Info ProviderManager: Saving image to /var/lib/emby/metadata/library/a3/a3b84c894f7f8af77a3d18e880e665d0/poster.jpg 2025-10-29 20:47:27.178 Error ProviderManager: Error saving to smb://192.168.178.34/Filme/Filme/Zärtliche Cousinen (1980)/poster.jpg. Failed to write to file. 2025-10-29 20:47:27.178 Info ProviderManager: Saving image to /var/lib/emby/metadata/library/18/18d6e5e94d884483e97f5c01c748eb68/poster.jpg 2025-10-29 20:47:38.048 Info ItemRefreshService-0HNGKOUCULV42:00000056: http/1.1 POST http://192.168.178.74:8096/emby/Items/20790/Refresh?Recursiv
Luke 42239 Posted October 30, 2025 Posted October 30, 2025 @supersaugiplease attach the complete log file. Thanks.
