Mahtan 3 Posted October 26, 2025 Posted October 26, 2025 Hello, I am experiencing a synchronization issue with my downloaded videos when trying to update the playback status back to the server from my tablet. The media files download successfully onto the tablet for offline viewing. However, once I reconnect to the internet (via Wi-Fi/4G), the resume point (where I stopped watching) and/ or the 'watched/unwatched' status is not being synced or updated on my Emby server. This means that when I attempt to resume the video on another client (such as a PC or TV), the video does not start at the correct position. Has anyone else encountered this issue, or is there a known solution or workaround? Thank you
Luke 42241 Posted October 26, 2025 Posted October 26, 2025 Hi, it does get synced, but it's not immediate. It happens during the next background sync with the server. Does that help answer your question?
Mahtan 3 Posted October 27, 2025 Author Posted October 27, 2025 (edited) 7 hours ago, Luke said: Hi, it does get synced, but it's not immediate. It happens during the next background sync with the server. Does that help answer your question? I connected my tablet to Wi-Fi when I got internet access again. But nothing happened. How is this background synchronization triggered? Can it be forced? The “problem” seems to lie in the management of downloads for files downloaded from a device. Because when I go to downloads => my series => I can see the episodes with the check mark. If I go to the same device but this time on the server because I am now connected, in the same series at that location I do not see the episodes with the check mark. The issue seems to be between the synchronization of the downloaded file and the file on the server. Edited October 27, 2025 by Mahtan
Luke 42241 Posted October 28, 2025 Posted October 28, 2025 Quote I connected my tablet to Wi-Fi when I got internet access again. But nothing happened. Once it's reconnected, restarting the app is one way to make the background sync happen right away.
Mahtan 3 Posted November 1, 2025 Author Posted November 1, 2025 On 10/28/2025 at 8:51 PM, Luke said: Once it's reconnected, restarting the app is one way to make the background sync happen right away. I left my tablet connected to Wi-Fi for several days, and I also restarted Emby several times by completely shutting it down on my tablet. But nothing worked. After all these attempts, I had one episode out of six that was marked as viewed on the server.
