upD8RP 2 Posted October 25, 2025 Posted October 25, 2025 I also use the standard app on Nvidia Shield, AFR works but it doesn't work for binge watching, i.e. the second episode falls back to the default frame rate.
Luke 42243 Posted October 26, 2025 Posted October 26, 2025 @upD8RP HI there, can you please provide a specific example? How to Report a Problem Thanks !
upD8RP 2 Posted October 28, 2025 Author Posted October 28, 2025 Okay, pls let me know what I could provide additionally. Setup: Nvidia Shield Pro ("latest" model), running Emby for Android 3.5.12. Playing DV UHD content with 24p on a Philips TV, app is configured tp match framerate but not resolution. 1st episode plays fine, no stuttering, 24p but I if I press "watch next episode" at the end of the 1st one, the screen is changing for a second to show the series wallpaper and then the next episode starts, this time with my GUI default framerate of 60. My TV shows the actual frame rate, so the values are not guessiing. I think, it only happens if I press "watch next episode" but I haven't found a pattern yet. embyserver.txt
Luke 42243 Posted November 14, 2025 Posted November 14, 2025 Hi, have you updated to Emby for Android 3.5.16? How does that compare?
Luke 42243 Posted November 21, 2025 Posted November 21, 2025 @upD8RPwhat should it be for the second episode?
upD8RP 2 Posted November 21, 2025 Author Posted November 21, 2025 24p content, I clicked "watch next episode" and it started in 60 FPS (which is my default Shield frame rate).
