cfoster 2 Posted October 25, 2025 Posted October 25, 2025 Having a remote access issue with emby server, its in docker on a Unraid PC. history is that I had an old server on the same WAN IP that is gone now and this one is in its place, this seems like it could be messing things up but I really dont know. I am getting this message on the android client when trying to connect remotely. '/dashboard-ui/manifest.json'
Solution tedfroop21 89 Posted October 26, 2025 Solution Posted October 26, 2025 I would assume you are port forwarding through your router, are this and the previous system both at the same internal IP so the port is forwarded properly? (or did you forward the port for the new servers address?)
cfoster 2 Posted October 26, 2025 Author Posted October 26, 2025 1 hour ago, tedfroop21 said: I would assume you are port forwarding through your router, are this and the previous system both at the same internal IP so the port is forwarded properly? (or did you forward the port for the new servers address?) your are correct, this solved it. adding my port forwarding list for reference. Service Name External Port Internal Port Internal IP Address Protocol Emby 8920 8920 192.168.x.x TCP Emby 8096 8096 192.168.x.x TCP Emby 7359 7359 192.168.x.x UDP 2
