JohnHagen 2 Posted October 21, 2025 Posted October 21, 2025 New user as of today, Oct 21. Just installed Emby and being frustrated with the new changes made to Plex. On my Home Page, I have a bout 20 TV Shows setup. They scroll horizontally, with the first one being mostly off screen to the left. Searching Google, it says to go to the settings - Display - CHange from Horizontal to Fixed via the App. I can't find anything even close. The Display menu in the RoKu App doesn't have this setting. Where can I make this change? Thanks! John
speechles 2062 Posted October 21, 2025 Posted October 21, 2025 31 minutes ago, JohnHagen said: They scroll horizontally, with the first one being mostly off screen to the left. What display resolution is your Roku set to use? Is it 4K or 1080P? What is the make/model of the TV you are using? There should be an overscan setting on the TV to allow the edges to show up. Are you possibly using "Zoom/Crop" on the TV instead of the "Normal" setting for the aspect ratio? It could be a number of things happening. Knowing the make/model of the TV would allow us to know which options on the TV you would need to check.
JohnHagen 2 Posted October 21, 2025 Author Posted October 21, 2025 No issues with the TV. It's at 1080p and no zoom capabilities. It's a Sony that is about 15 years old, flat screen. I did reboot the Roku and it looks like that may have fixed it. Still setting up more libraries so we'll see what happens. Thanks for the suggestions! John 1 1
