visproduction 335 Posted December 23, 2025 Posted December 23, 2025 Can a reference to "films-Davey" remain in Emby dabse, if just the file folder was deleted and Emby was not used to delete the media? I would think a 'Scan all libraries' might fix this. 1
Luke 42241 Posted December 29, 2025 Posted December 29, 2025 And can you please provide a log from the Android app: Thanks
Luke 42241 Posted December 29, 2025 Posted December 29, 2025 On 11/11/2025 at 4:37 PM, Davey's said: Almost a week later, I'm curious what can be done about it because Emby sometimes stops playing content What happens when you try to play?
Davey's 40 Posted January 22 Author Posted January 22 Hi, yesterday I had another error in Emby.(See attached) Without immediately dismissing it, I chose to play some content. I successfully played some FLAC files until the Android version restarted. Or maybe the app suddenly lost its playlist and stopped playing content.
Luke 42241 Posted January 22 Posted January 22 I think this should be resolved in the next update to the app. Thanks. 1
Davey's 40 Posted January 24 Author Posted January 24 On 12/30/2025 at 12:32 AM, Luke said: Do you also see this in the web app? @visproduction This shouldn't be happening anymore, as I manually enter the action to update the library 2-3 times a month. Sorry for the late reply, I just discovered it in the web app too, see attached. hopefully a total restart on the DS918+ will work for now.. fingers crossed
Luke 42241 Posted January 24 Posted January 24 1 hour ago, Davey's said: @visproduction This shouldn't be happening anymore, as I manually enter the action to update the library 2-3 times a month. Sorry for the late reply, I just discovered it in the web app too, see attached. hopefully a total restart on the DS918+ will work for now.. fingers crossed Hi there, please attach the Emby server log from when the problem occurred: How to Report a Problem Thanks!
