horstepipe 424 Posted October 20, 2025 Posted October 20, 2025 Hello I wanted to enable Cinema Intros on my server again, it is stable v4.9.1.80. Here are my settings: If I start any movie, I don't get a trailer. The movie just starts. Shouldn't I get trailers of new movies now?
GrimReaper 4926 Posted October 20, 2025 Posted October 20, 2025 Does your Movie library show any trailers in Trailers tab?
horstepipe 424 Posted October 20, 2025 Author Posted October 20, 2025 yes, almost all are not viewed yet...
GrimReaper 4926 Posted October 20, 2025 Posted October 20, 2025 (edited) Just tested on 4.9.1.80 Web app, have no issues. Edit: Is CinemaIntros enabled in client app? Edited October 20, 2025 by GrimReaper
horstepipe 424 Posted October 20, 2025 Author Posted October 20, 2025 9 minutes ago, GrimReaper said: Just tested on 4.9.1.80 Web app, have no issues. Edit: Is CinemaIntros enabled in client app? After I enabled the trailer archive, these trailers seem to work, too - at least in webapp, getting errors in App for Windows. But this is another problem for sure. Do you have that enabled, too?
GrimReaper 4926 Posted October 20, 2025 Posted October 20, 2025 No, I replicated your settings, only New and Upcoming in Trailers and Movies+New and upcoming in Cinema Intros.
horstepipe 424 Posted October 20, 2025 Author Posted October 20, 2025 hmm okay, strange. I will prepare some logs, then. Thanks
GrimReaper 4926 Posted October 20, 2025 Posted October 20, 2025 Enable Debug logging, so you'll see trailer playback attempt entries/links, if any. 1
