Hey Folks
I put together a smart back drop generator, which can produce random video clips or the more advanced option to try and capture scenes based on ( audio, visual or music)
If you are technical, you can get what you need from the zip file directly.
Best option is to extract all content and copy all content to chat window in Claude.ai ( Or Chat GPT or your ai of choice) And it will walk you through setup, configuration,  best practice and diagnostics based on lessons learned for Windows, Mac, Linux and Docker
Enjoy
smart-backdrop-generator-deploy.zip
I have to fix this to work with various Ai models. Bear with me
Sounds cool! Can you show us example?
Use this V2 version instead
Access Claude.ai and signup / login. You can use the "free" Haiku 4.5 / sonnet 4.5 version.
Extract all files to your local system > drag and drop all files into the chat window and type
"help me get setup"
p.s. Claude was used to develop content and the implementation guide, so stick with it. Other Ai agents have limitations on number of files.
have fun and let me know how you progress.
smart-backdrop-generator-deploy V2.zip
