Luke 42243 Posted October 18, 2025 Posted October 18, 2025 When you customize the image, how are you doing that?
Happy2Play 9812 Posted October 18, 2025 Posted October 18, 2025 22 minutes ago, Luke said: When you customize the image, how are you doing that? What do you mean as there is only one way to apply My Media images now as there are no longer folders as it db only info? But reproduce having custom image on My Media, select Refresh w/replace image replaces Custom My Media image also with new dynamic image.
Tophicles 40 Posted October 18, 2025 Author Posted October 18, 2025 26 minutes ago, Luke said: When you customize the image, how are you doing that? I'm clicking on the library, edit images, delete the primary and upload my custom.
Luke 42243 Posted October 18, 2025 Posted October 18, 2025 20 minutes ago, Happy2Play said: But reproduce having custom image on My Media, select Refresh w/replace image replaces Custom My Media image also with new dynamic image. OK i missed the part where that checkbox was checked. So yes that is currently expected behavior.
Tophicles 40 Posted October 18, 2025 Author Posted October 18, 2025 1 minute ago, Luke said: OK i missed the part where that checkbox was checked. So yes that is currently expected behavior. Right, so that's where it would be helpful to "lock" the image, if you understand what I mean.
howllor 28 Posted October 18, 2025 Posted October 18, 2025 Is there a specific reason why you're replacing all images every time instead of just looking for missing images? Because just... not doing that, would seem like the easiest fix? 1
Tophicles 40 Posted October 18, 2025 Author Posted October 18, 2025 20 minutes ago, howllor said: Is there a specific reason why you're replacing all images every time instead of just looking for missing images? Because just... not doing that, would seem like the easiest fix? I only see a toggle to replace all images? If I leave that untoggled, will it only look for missing ones? When I run it untoggled, it does not fill in the missing artwork.
Tophicles 40 Posted October 18, 2025 Author Posted October 18, 2025 22 minutes ago, howllor said: Is there a specific reason why you're replacing all images every time instead of just looking for missing images? Because just... not doing that, would seem like the easiest fix? PS - kudos on the Moomin avatar 1
Happy2Play 9812 Posted October 18, 2025 Posted October 18, 2025 Might need a specific example of where Search for Missing is not getting missing artwork. But technically that is all you should need if you are only looking for something that is missing.
howllor 28 Posted October 18, 2025 Posted October 18, 2025 6 minutes ago, Tophicles said: I only see a toggle to replace all images? If I leave that untoggled, will it only look for missing ones? When I run it untoggled, it does not fill in the missing artwork. Well, it should fill in missing artwork when you leave it untoggled, so that might be your problem there. You shouldn't have to replace everything.
Tophicles 40 Posted October 18, 2025 Author Posted October 18, 2025 4 minutes ago, howllor said: Well, it should fill in missing artwork when you leave it untoggled, so that might be your problem there. You shouldn't have to replace everything. Noted. I'll give it another go.
