Scorpio86 0 Posted October 17, 2025 Posted October 17, 2025 Just updated to latest server and now the embedded cover art for the audio books are not showing. These showed prior to the update and when logging into the storage the thumbnails load and display the covers fine. When loading on the emby app all audiobooks show but with no covers. Files are M4b, art is embedded in the file. Server on Nvidia Shield
Luke 42237 Posted October 20, 2025 Posted October 20, 2025 @Scorpio86 HI there, can you please provide a specific example? How to Report a Problem Thanks !
Scorpio86 0 Posted October 20, 2025 Author Posted October 20, 2025 Prior to the server update all artwork showed with no issues. Since the server update all the files in the emby app play fine but show no cover artwork it's just a black square. I have tried removing the file and responding and I have added a new file and still the same. The file on my phone in files displays the cover art automatically as it did in the previous server but now it does not. I have also had issues with this server shutting down on its own which didnt happen with the previous either. I might try the stable update to see if this fixes it I have not done anything different with settings or storage location or files. The only thing that changed was the server
Luke 42237 Posted October 26, 2025 Posted October 26, 2025 @Scorpio86are you still having an issue with this? Can you please show us a specific example of what you are seeing? Thanks !
Scorpio86 0 Posted November 18, 2025 Author Posted November 18, 2025 It appeared to be an issue with the beta server. Once I moved to the stable it fixed the issue Thanks
Luke 42237 Posted November 18, 2025 Posted November 18, 2025 @Scorpio86 HI there, can you please provide a specific example? How to Report a Problem Thanks !
