MAX92 93 Posted October 14, 2025 Posted October 14, 2025 Mes vidéos ne passent en automatique sur EDGE. Il faut que je lance "Correction de la lecture" pour que la video se lance. Je n'avais pas ce problème avant, j'ai l'impression que c'est avec la nouvelle version de EMBY. embyserver.txt
Luke 42239 Posted October 14, 2025 Posted October 14, 2025 Can you install it to see how it compares? Anyway this is an issue in the Edge video player. The web app automatically switches to server transcoding so that it will still play successfully.
MAX92 93 Posted October 14, 2025 Author Posted October 14, 2025 Yes, transcoding video works. I don't remember if it was necessary.
MAX92 93 Posted October 15, 2025 Author Posted October 15, 2025 On Chrome, works with transcodification
Luke 42239 Posted October 22, 2025 Posted October 22, 2025 OK it sounds like an issue in the Edge video player. I would suggest retrying this anytime there is an Edge browser update or Windows OS update.
