KingSlowDown 3 Posted October 14, 2025 Posted October 14, 2025 So, usually with my file structure like this; -> Series -> Specials -> Season 1 Emby always spat the "Specials" folder out as a separate season like in this first screenshot, but on some shows it instead changes the season name to "Extras" and shows me it below Season 1, instead of side by side as seasons like usual. Is there anything I can do to fix this? Or is it doing that because the Series only contains one season?
Abobader 3491 Posted October 14, 2025 Posted October 14, 2025 Hello KingSlowDown, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
GrimReaper 4926 Posted October 14, 2025 Posted October 14, 2025 (edited) How are files named in your Specials folder (seems it's not recognized as a special episode, maybe missing season 0 identifier, i.e. S00Exx)? If you rename folder to Season 0, how does it compare? What is your preferred series display in your user preferences>Display tab? Edited October 14, 2025 by GrimReaper Screenshot
KingSlowDown 3 Posted October 14, 2025 Author Posted October 14, 2025 (edited) Files in the special folder always use the S00E01 format (for Season 0) Renaming the Specials folder to Season 0 didn't change anything though. I use the "Show all episodes for single season series" display option, and while "Always show season folders" obviously fixes my issue, for every series with only one season I'd need to rename every "Season 1" for my liking, which I'm not really down to do for 150 shows, especially when only two whole shows in my catalogue have that specific issue Edited October 14, 2025 by KingSlowDown typo
GrimReaper 4926 Posted October 14, 2025 Posted October 14, 2025 6 minutes ago, KingSlowDown said: for every series with only one season I'd need to rename every "Season 1" for my liking, which I'm not really down to do for 150 shows Not sure what do you mean by that, why would you rename any Season 1 folder? 10 minutes ago, KingSlowDown said: Files in the special folder always use the S00E01 format (for Season 0) Based on your screenshot and that Extras episode title, that particular episode was not recognized as a special episode, could you share About section details from the bottom of episode detail screen?
KingSlowDown 3 Posted October 14, 2025 Author Posted October 14, 2025 (edited) 5 minutes ago, GrimReaper said: Not sure what do you mean by that, why would you rename any Season 1 folder? At least with anime Emby often changes up the Season names (for specific arcs or whatever), that's what I meant And Emby does recognize it as a Special episode (At least it says "Special -") and it's also using the correct TVDB metadata Edited October 14, 2025 by KingSlowDown added screenshot
GrimReaper 4926 Posted October 14, 2025 Posted October 14, 2025 2 minutes ago, KingSlowDown said: And Emby does recognize it as a Special episode (At least it says "Special -") and it's also using the correct TVDB metadata In that case I'm unclear why it would be listed under Extras instead of inline with other Season 1 episodes. Maybe the Dev might have some idea. @Luke
Luke 42289 Posted October 14, 2025 Posted October 14, 2025 They are special episodes. All it's doing is splitting them onto their own line and separating them from the regular episodes. The title of the section is Specials, not Extras. I think this is an error with the german translation. 1
KingSlowDown 3 Posted October 14, 2025 Author Posted October 14, 2025 So I guess there's no way to change that unless I use "Always show season folders"?
GrimReaper 4926 Posted October 14, 2025 Posted October 14, 2025 (edited) 13 minutes ago, Luke said: They are special episodes. All it's doing is splitting them onto their own line and separating them from the regular episodes. Does that mean that behavior is changed for 4.9 branch? As in 4.8 I'm getting specials displayed inline for single season shows? Edit: Scratch that, just tested on 4.9 and it indeed adds new row for Specials and episode title doesn't have "Special - " prefix any more. So you're right, it's just translation issue. Edited October 14, 2025 by GrimReaper Tested
Luke 42289 Posted October 14, 2025 Posted October 14, 2025 8 minutes ago, KingSlowDown said: So I guess there's no way to change that unless I use "Always show season folders"? Wouldn't it make more sense if the heading title were Specials? Would you even have thought twice if that were the case?
Luke 42289 Posted October 14, 2025 Posted October 14, 2025 But please note - episodes that have special episode placement, e.g. "airs before episode"...those will still be inline with the regular episodes.
KingSlowDown 3 Posted October 14, 2025 Author Posted October 14, 2025 5 minutes ago, Luke said: Wouldn't it make more sense if the heading title were Specials? Would you even have thought twice if that were the case? I'm just used to all other Specials I have showing up as a season next to the normal seasons, so having only two outliers is kinda annoying haha 1
Luke 42289 Posted October 14, 2025 Posted October 14, 2025 You can always assign them airs before season/episode values, but of course that will cause them to be treated more like regular episodes, meaning showing in continue watching.
