lovexyh 1 Posted October 14, 2025 Posted October 14, 2025 When I installed Android Universal Edition on Sony TV and played TV series, it was not as convenient as Android TV Edition to watch the next episode. In the Android TV version, I just need the remote control to press the down arrow, and there will be a button to jump directly to the next episode below the progress bar, which is not available in the Android universal version, and it needs multi-step selection. I don't know if I have a setup problem or I really don't have this function. If I don't have this function, I hope to add this function in subsequent versions. Thank you!
GrimReaper 4896 Posted October 14, 2025 Posted October 14, 2025 19 minutes ago, lovexyh said: I just need the remote control to press the down arrow, and there will be a button to jump directly to the next episode below the progress bar, which is not available in the Android universal version, and it needs multi-step selection. New behaviour/UI design (for better or worse) in almost all client apps:
lovexyh 1 Posted October 14, 2025 Author Posted October 14, 2025 2 minutes ago, GrimReaper said:两分钟前,GrimReaper说道: New behaviour/UI design (for better or worse) in almost all client apps: 几乎所有客户端应用程序都采用了新的行为/用户界面设计——无论这些变化是好是坏。 It turns out that so many people have reported ... I hope it will be solved soon! 原来有那么多人都报告了这个问题……希望这个问题能尽快得到解决!
Luke 42241 Posted October 14, 2025 Posted October 14, 2025 Hi there, can you please show a screenshot of what you see? What version number do you have installed?
lovexyh 1 Posted October 14, 2025 Author Posted October 14, 2025 (edited) 17分钟前,Luke说: 你好,你能给我看你看到的截图吗?你安装了什么版本号? The version is 3.5.12. In the past, when using the Android TV version, there was a navigation button directly under the progress bar to jump to the next episode. Now you need to select "Next Play(下个播放)" to select, and the playback progress in "Next Play" is often not updated in real time, resulting in the wrong selection, and the playback has been seen again. I really hope to add the function of jumping to the next episode in the Android TV version, and optimize the TV mode in the Android general version. The smoothness and other aspects are not as comfortable as the Android TV version at present.Or, add ending detection and skipping? I'm not sure if it's because of the software design. There has been no skip ending function in the TV mode of emby, and I use infuse to directly connect to the emby media library for playback. Most of the time, there will be an option to skip the ending. With this function, it will also greatly improve the comfort of watching movies. Note: It is to skip the ending directly, not the "continue to play" or "play the next one" displayed after a period of time at the end of the ending. Thank you! Edited October 14, 2025 by lovexyh
Solution seanbuff 1356 Posted October 14, 2025 Solution Posted October 14, 2025 It looks like you may have transport controls hidden. You need to unhide transport buttons in your App Settings under 'Playback' Change that to 'No'
lovexyh 1 Posted October 14, 2025 Author Posted October 14, 2025 3 hours ago, seanbuff said: It looks like you may have transport controls hidden. You need to unhide transport buttons in your App Settings under 'Playback' Change that to 'No' So that's it! It's solved, thank you very much! 1
