Geoffevans42 1 Posted October 13, 2025 Posted October 13, 2025 (edited) Hi there, In the past week or two, I've found that Emby has started disobeying the "play next episode automatically" setting. I have it turned off, but when I play an episode of a show, it continues through the season. I did have a look at this topic, but the relevant step of "turn it on, then off" had no effect. This is happening in the web client and the Android client. Logs attached. Thanks in advance for the help. embyserver.txt Edited October 13, 2025 by Geoffevans42 Forgot the link
Luke 42289 Posted October 13, 2025 Posted October 13, 2025 Hi there, how exactly did you start playing?
Geoffevans42 1 Posted October 13, 2025 Author Posted October 13, 2025 Played the episode from continue watching, but it also occurs when selecting an individual episode from a season.
Luke 42289 Posted October 13, 2025 Posted October 13, 2025 How have you configured your user options?
Luke 42289 Posted October 13, 2025 Posted October 13, 2025 OK and what makes you think the next episode is playing is playing automatically?
Geoffevans42 1 Posted October 13, 2025 Author Posted October 13, 2025 It's been happening when I play Star Trek episodes at night to sleep. I'll wake up, and it'll have gone onto another episode. I just opened an episode to test on my laptop, skipped right to the end, and it proceeded to start the next one.
Geoffevans42 1 Posted October 13, 2025 Author Posted October 13, 2025 Just tested again, and the "Next episode" button started advancing:
Geoffevans42 1 Posted October 13, 2025 Author Posted October 13, 2025 Well, oddly enough, nothing happened on my PC. But I just now tested on my Android tablet, and it did start playing the next episode. 1
