bobbee001 4 Posted October 14, 2025 Author Posted October 14, 2025 (edited) I have premier I used and was content with PLEX for years, but their new interface is horrible. So I load emby, its real good except this trailer business is might confusing. Scheduled tasks don't see ytrailers, is it Radeon's Tools Download Local YouTube Movie Trailers Stopping Edited October 14, 2025 by bobbee001
bobbee001 4 Posted October 15, 2025 Author Posted October 15, 2025 So I woke up this morning, trailers are showing up on Roku. What finally fixed it is beyond me, but it works. Took many confusing terms with simply trying to get movie trailers. If shouls be as simple as download ytrailers from this address Install in emby plugin directory Set a, b and c Thanks to those who provided this assistance.
bobbee001 4 Posted October 15, 2025 Author Posted October 15, 2025 WAIT - I went on Roku and I had a couple of trailers, I now I didn't start plex in error because the trailer option was adjacent to the play etc (on plex in is under). Now it is 8am, NO TRAILERS ??????>
bobbee001 4 Posted October 15, 2025 Author Posted October 15, 2025 (edited) Using Roku with emby, a movie showed pllay resume trailer etc all one the same line I went back a few hours later, no trailer ????? I am about ready to quit trying, frustration. Edited October 15, 2025 by bobbee001
Luke 42285 Posted October 15, 2025 Posted October 15, 2025 14 minutes ago, bobbee001 said: Using Roku with emby, a movie showed pllay resume trailer etc all one the same line I went back a few hours later, no trailer ????? I am about ready to quit trying, frustration. HI, apologies for the frustration. Most of our other apps play trailers using youtube but unfortunately this is not possible on Roku, so that's why you need your own trailer video files. Can you please show us an example of what you are explaining? Thanks.
speechles 2062 Posted October 15, 2025 Posted October 15, 2025 (edited) 1 hour ago, Luke said: HI, apologies for the frustration. Most of our other apps play trailers using youtube but unfortunately this is not possible on Roku, so that's why you need your own trailer video files. Can you please show us an example of what you are explaining? Thanks. @LukeHe is using ytrailers plugin from Radeon to acquire YouTube trailers locally with his media. They should always exist once downloaded. @bobbee001It may show what is happening in your Emby Server logs. They should not be getting deleted. The plugin downloads the links from YouTube directly to the folder of the item it is scanning is in. Edited October 15, 2025 by speechles
bobbee001 4 Posted October 15, 2025 Author Posted October 15, 2025 I ma traveling today, what is the recommendation for tomorrow
speechles 2062 Posted October 15, 2025 Posted October 15, 2025 (edited) 5 hours ago, bobbee001 said: I ma traveling today, what is the recommendation for tomorrow The Radeons tools task for Local YouTube Movie Trailers shows stopping in your screenshot. You might need to restart Emby server. Then afterwards have it start that scheduled task again. It should just work. Edited October 15, 2025 by speechles
bobbee001 4 Posted October 16, 2025 Author Posted October 16, 2025 I am back, windows 11 and the trailers are there Roku - no trailer
bobbee001 4 Posted October 16, 2025 Author Posted October 16, 2025 Attached log file embyserverlog.txt
bobbee001 4 Posted October 17, 2025 Author Posted October 17, 2025 AI response: In other words: If the YTrailers plugin is pulling trailers dynamically from YouTube (or similar web sources), that will show up in the server/web UI, but the Roku app will not show or allow those trailers. Hence: trailers “work” when viewed from the server (or web client) but do not show on Roku.
Happy2Play 9814 Posted October 17, 2025 Posted October 17, 2025 10 minutes ago, bobbee001 said: AI response: In other words: If the YTrailers plugin is pulling trailers dynamically from YouTube (or similar web sources), that will show up in the server/web UI, but the Roku app will not show or allow those trailers. Hence: trailers “work” when viewed from the server (or web client) but do not show on Roku. Sorry but I have local trailers with most of my media and Roku plays them just fine. If you do not have local trailers, they there will not be a trailer icon as Roku will not allow the URL to be launched in the Emby app.
speechles 2062 Posted October 17, 2025 Posted October 17, 2025 (edited) Quote 2025-10-16 14:49:16.053 Info LibraryMonitor: Winter Love Story - Trailer (D:\Light\Winter Love Story 2019 Hallmark 720p HDTV X264 Solar-trailer.mp4) will be refreshed. Are your movies put into individual folders or just lumped together into the D:\Light directory? You will find the trailer in there that was downloaded then the library gets refreshed and it should show up. Are there trailers in D:\Light? When you added the library did you add it as "D:\Light" or just "D:"? If you add it as just "D" it may confuse the server with your subfolder structure. Edited October 17, 2025 by speechles
ebr 16352 Posted October 19, 2025 Posted October 19, 2025 On 10/17/2025 at 11:10 AM, bobbee001 said: yes, as shown As shown, it is UNchecked. Can you please try checking it?
Luke 42285 Posted October 19, 2025 Posted October 19, 2025 @bobbee001please let us know if this helps. Thanks.
ebr 16352 Posted October 19, 2025 Posted October 19, 2025 1 hour ago, bobbee001 said: I don't have local trailers As explained previously, the Roku app cannot play the players directly from YT (well, they could but it would be a horrible user experience). I thought that was why you installed that other plugin - to retrieve local trailers.
Solution Luke 42285 Posted October 20, 2025 Solution Posted October 20, 2025 4 hours ago, bobbee001 said: I don't have local trailers Right, for Emby on Roku you will need local trailer files. Hopefully we'll be able to use Youtube trailers in the future on Roku, but as of today, we cannot.
