emby-newb 2 Posted October 12, 2025 Posted October 12, 2025 Hey everyone, first time using/setting up emby, on truenas scale. I have everything setup and media scanning for metadata. Well, my stupidass disabled remote access thinking it would disable WAN connectivity, and now I'm locked out. I get "forbidden" whenever I plug in the LAN IP address of the server. Am I destined to reinstall everything again? Thanks
Solution Happy2Play 9811 Posted October 12, 2025 Solution Posted October 12, 2025 You will have to shutdown Emby and edit your system.xml to reenable it. Do not now this platform path but looks something like this Data path: /var/db/emby-server/config 1
emby-newb 2 Posted October 12, 2025 Author Posted October 12, 2025 (edited) Thanks @Happy2Playgot my access back. How do I delete WAN access? The documentation says to untick remote access, which is what got me here https://emby.media/support/articles/Hosting-Settings.html?q=disable wan Edited October 12, 2025 by emby-newb
Happy2Play 9811 Posted October 12, 2025 Posted October 12, 2025 3 minutes ago, emby-newb said: Thanks @Happy2Playgot my access back. How do I delete WAN access? The documentation says to untick remote access, which is what got me here https://emby.media/support/articles/Hosting-Settings.html?q=disable wan That is the correct way, but I guess the real question is why is your connection considered Remote? You may have to add your local network to LAN Networks but not enough info on your overall setup.
emby-newb 2 Posted October 13, 2025 Author Posted October 13, 2025 Thanks again for the reply. As I mentioned I am using TrueNAS Scale NAS, it uses/has docker apps so I installed emby on one. I followed the emby wizard to set the path for media (music, movies etc), after next next next, it starts the service and I can access everything. The IP addresses and access settings are set by default.
Happy2Play 9811 Posted October 13, 2025 Posted October 13, 2025 Sorry don't know anything about the platform so some else will have to comment on this local connection issue being seen as Remote. 1
Luke 42234 Posted October 13, 2025 Posted October 13, 2025 Hi, @emby-newbyou’ll need try edit the server config file to undo the changes. You can find it by locating the server data folder: Emby Server Data Folder then going from the to/config/system.xml look for the EnableRemoteAccess node and set it to true. Then start the server. Please let us know if this helps. Thanks. 1
emby-newb 2 Posted October 13, 2025 Author Posted October 13, 2025 1 hour ago, Luke said: Hi, @emby-newbyou’ll need try edit the server config file to undo the changes. You can find it by locating the server data folder: Emby Server Data Folder then going from the to/config/system.xml look for the EnableRemoteAccess node and set it to true. Then start the server. Please let us know if this helps. Thanks. Yes sir, that fixed it. Thank you much! 1
