Squatter9143 0 Posted October 12, 2025 Posted October 12, 2025 Hello, I'm running Emby 4.9.1.80 under MacOS. In the release notes of 4.9.1.80 it shows "Update to .NET 8"; however, the log is showing the .NET Framework as 6.0.36 (see image). Is something off with my install? Thanks for any info.
Luke 42237 Posted October 12, 2025 Posted October 12, 2025 Hi, macOS is going to stay on dotnet 6 for a bit longer.
