AJV_20 58 Posted October 11, 2025 Posted October 11, 2025 I'm running TrueNAS ElectricEel-24.10.2.4. I just moved my library from MacOS and it doesn't seem to detect the integrated gpu for hardware transcoding.
kikinjo 294 Posted October 11, 2025 Posted October 11, 2025 Reported similar on other thread (didnt see this one, seems detection broken on last 2 beta versions. I have provided logs in other thread.
AJV_20 58 Posted October 11, 2025 Author Posted October 11, 2025 Thanks, and I can’t go to stable for some reason
Luke 42242 Posted October 11, 2025 Posted October 11, 2025 1 hour ago, AJV_20 said: Thanks, and I can’t go to stable for some reason HI there, what makes you think you "can't go to stable" ?
AJV_20 58 Posted October 11, 2025 Author Posted October 11, 2025 2 hours ago, Luke said: HI there, what makes you think you "can't go to stable" ? I’m still learning to use truenas but I don’t see an option to be on the stable build. When I installed it, it went straight to the latest beta build
Luke 42242 Posted October 22, 2025 Posted October 22, 2025 On 10/11/2025 at 4:55 PM, AJV_20 said: I’m still learning to use truenas but I don’t see an option to be on the stable build. When I installed it, it went straight to the latest beta build HI, yes there's more discussion on that here:
