WhiteStig 2 Posted October 10, 2025 Posted October 10, 2025 I just switched over from Plex to try the live TV implementation on Emby. I have issues with it on Native, there is a significant amount of screen flicker or tearing. When I switched to MPV I got the audio synch issues. I did the turn off match framerate fix but that only works for a bit, the audio eventually gets out of synch again. I've been through the forum and didn't see and definitive fixes. I'd like to get this fixed.
WhiteStig 2 Posted October 10, 2025 Author Posted October 10, 2025 47 minutes ago, WhiteStig said: I just switched over from Plex to try the live TV implementation on Emby. I have issues with it on Native Auto, is is using MPV renderer and there is a significant amount of screen flicker or tearing. When I switched to MPV Native I got the audio synch issues. I did the turn off match framerate fix but that only works for a bit, the audio eventually gets out of synch again. I've been through the forum and didn't see and definitive fixes. I'd like to get this fixed. Didn't see a way to edit.....got them flipped in original post. Sorry.
Luke 42239 Posted October 11, 2025 Posted October 11, 2025 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
