BiggusThiccus 0 Posted October 9, 2025 Posted October 9, 2025 Hi, Can we get a stat in Stats for Nerds about the download speed we are getting from our ISP to whatever device we are using?
Luke 42243 Posted October 9, 2025 Posted October 9, 2025 Hi, we can try but not every app can get this info from the player during playback.
BiggusThiccus 0 Posted October 9, 2025 Author Posted October 9, 2025 Do you know what apps may be able to? I use the LG app, and (i dont know if you know this) the LG C1 has poor Internet speeds unless over wifi. even then, I need to try and trick it into using 5ghz bandwidth by turning it off and on again. I believe wired it 100mbps and wireless can maybe up to 300mbps. Put it like this, I can stream 4K direct 2ith minimal issue on wireless but wired, it's extremely spotty.
ebr 16336 Posted October 10, 2025 Posted October 10, 2025 12 hours ago, BiggusThiccus said: I believe wired it 100mbps and wireless can maybe up to 300mbps Hi. That is typical for a smart TV. The manufacturers spend as little as possible on the network interface because literally almost no one uses a wired connection.
ebr 16336 Posted October 10, 2025 Posted October 10, 2025 Hi, there's already an open request for this or something functionally equivalent. Please join in and contribute to the existing discussion at:
