asgard25 54 Posted October 24, 2025 Author Posted October 24, 2025 1 hour ago, vincen said: Little display bug: you don't take care of local settings of Android, dates are always displayed US format My phone is setup in french and so display dates as DD/MM/YY but in Embywatch it shows up everywhere as MM/DD/YY. Thanks Hello, no, the dates depend on the language chosen in the application, this is intentional, thank you. 1
hspantera 8 Posted October 24, 2025 Posted October 24, 2025 Do will be available in iOS? If yes any date of realease? Thanks.
vincen 72 Posted October 24, 2025 Posted October 24, 2025 1 minute ago, hspantera said: Do will be available in iOS? If yes any date of realease? Thanks.
asgard25 54 Posted October 24, 2025 Author Posted October 24, 2025 (edited) 47 minutes ago, hspantera said: Do will be available in iOS? If yes any date of realease? Thanks. Hello, this is not planned. I am the only one managing the two Android applications. I cannot do iOS in addition. Edited October 24, 2025 by asgard25
asgard25 54 Posted October 24, 2025 Author Posted October 24, 2025 (edited) New Version Submitted! Hey everyone! New update is on its way to Google Play (approval 24–72h). Embywatch → v1.1.REV-21 New: Added support for Jellysatt as an external service. Added a short introductory tutorial to guide new users through the main features. Improvements: Removed the left sidebar menu and moved it to a bottom sheet for better usability. Stay tuned – it’ll be live soon! Edited October 24, 2025 by asgard25 1
Jdiesel 1435 Posted October 24, 2025 Posted October 24, 2025 I'll give Jellystat a go but my issue with using it is that I'll need to expose it to the internet to have reliable results. I don't like exposing services to the internet if possible. I use a VPN connection when connecting to my arr apps remotely but I feel like accessing the stats would work best with a continuous connection. Regardless, I'll test it out.
asgard25 54 Posted October 24, 2025 Author Posted October 24, 2025 2 hours ago, Jdiesel said: I'll give Jellystat a go but my issue with using it is that I'll need to expose it to the internet to have reliable results. I don't like exposing services to the internet if possible. I use a VPN connection when connecting to my arr apps remotely but I feel like accessing the stats would work best with a continuous connection. Regardless, I'll test it out. You don't have to expose it on the internet, you put it locally and you will only have the data locally
Jdiesel 1435 Posted October 24, 2025 Posted October 24, 2025 If I access EmbyWatch remotely I won't get the data though, correct? Unless I'm connected via my VPN. It's not a deal breaker but the advance to get stats directly via Emby is that it doesn't require a second service running. I'll try it out and see if it's worth the extra software and steps over the Playback Reporting plugin which is all built in. 1
asgard25 54 Posted October 24, 2025 Author Posted October 24, 2025 1 hour ago, Jdiesel said: If I access EmbyWatch remotely I won't get the data though, correct? Unless I'm connected via my VPN. It's not a deal breaker but the advance to get stats directly via Emby is that it doesn't require a second service running. I'll try it out and see if it's worth the extra software and steps over the Playback Reporting plugin which is all built in. You have to use the method that suits you best
sh0rty 727 Posted October 25, 2025 Posted October 25, 2025 (edited) 18 hours ago, asgard25 said: You don't have to expose it on the internet, you put it locally and you will only have the data locally It would be nice if user could set up multiple custom authentication header fields in Embywatch for every service the App grabs the data from (Emby, Radarr, Sonarr, Jellystat, Jellyseer). e.g. AuthHeaderName: NameValue AuthHeaderToken: TokenValue e.g.: Access-Token-Id: ad70a9f890as Access-Token: 098aß70ßd7as8da90d88asaasd With this, you can lock down Emby, Radarr, Sonarr, Jellystat, Jellyseer behind Reverse Proxy to the public with all the bells and whistles like 2FA etc., but Embywatch could authenticate with the Headers to bypass the security when not at home -> no VPN needed and Embywatch notifications working without VPN. Conduit for OpenWebUI and Immich for images implemented this some time ago and this works awesome with e.g. Traefik as Reverse Proxy. Edited October 25, 2025 by sh0rty 1 1
sh0rty 727 Posted October 26, 2025 Posted October 26, 2025 (edited) Just an addition to the above while @asgard25tries to implement it in Embywatch: Custom Headers would also be beneficial for the Emby Client apps. @Luke@softworkz See: Edited October 26, 2025 by sh0rty 1
asgard25 54 Posted November 9, 2025 Author Posted November 9, 2025 New Version Submitted! Hey everyone! New update is on its way to Google Play (approval 24–72h). Embywatch → v1.1.REV-86 ### 🛠 Fixes - Fixed shop item issues - Fixed avatar frame display - Fixed price display bug in the shop - Corrected shop item text (requires testing in beta environment) - Fixed shop item descriptions ### Improvements - Added the option to display your avatar in the preview frame - Increased avatar size on the dashboard - Added animations to the bottom menu closing function - Optimize time loading history and user time history ### Additions - Added premium items to the shop - Added new items to the shop - Added a "?" button to the shop for explanation - Google in-app Update ### Changes - Removed the external service item from the “More” menu - Moved the Jellyseer notification badge to the bottom menu notch Stay tuned – it’ll be live soon! Already available for beta testers
sh0rty 727 Posted November 11, 2025 Posted November 11, 2025 On 11/9/2025 at 9:06 PM, asgard25 said: New Version Submitted! Hey everyone! New update is on its way to Google Play (approval 24–72h). Embywatch → v1.1.REV-86 ### 🛠 Fixes - Fixed shop item issues - Fixed avatar frame display - Fixed price display bug in the shop - Corrected shop item text (requires testing in beta environment) - Fixed shop item descriptions ### Improvements - Added the option to display your avatar in the preview frame - Increased avatar size on the dashboard - Added animations to the bottom menu closing function - Optimize time loading history and user time history ### Additions - Added premium items to the shop - Added new items to the shop - Added a "?" button to the shop for explanation - Google in-app Update ### Changes - Removed the external service item from the “More” menu - Moved the Jellyseer notification badge to the bottom menu notch Stay tuned – it’ll be live soon! Already available for beta testers Don't know what you did and if you did something, but Jellyseer now works for me. 1
Mahtan 3 Posted November 14, 2025 Posted November 14, 2025 Hello, I really enjoyed this app and upgraded to premium very quickly. First of all, I want to congratulate you on the design and features. I have a question: I manage my Emby automatically using radar and sonar. Would it be possible to add a notification service to Emby Watch so that I can be notified when a file downloads automatically? 1
Grimmer 15 Posted November 17, 2025 Posted November 17, 2025 Is it just me? Or is the "add server" password field, not marked as a password field? It is trying to add punctuation and remember what I type as a suggestion. Normal password entry fields have all of this disabled.
asgard25 54 Posted November 17, 2025 Author Posted November 17, 2025 On 11/14/2025 at 11:05 PM, Mahtan said: Hello, I really enjoyed this app and upgraded to premium very quickly. First of all, I want to congratulate you on the design and features. I have a question: I manage my Emby automatically using radar and sonar. Would it be possible to add a notification service to Emby Watch so that I can be notified when a file downloads automatically? Hello, this is not planned at the moment.
Jdiesel 1435 Posted November 21, 2025 Posted November 21, 2025 I've been using the app for the past few weeks and generally I do like having information in one location. My only complaint is that the app is becoming a bit spammy with notifications, especially since I have notifications disabled in the app itself. I'm not interested in joining the discord, raffles for premium which I already have, or other apps. Especially as a premium user. I understand being compensated for development but the store is unappealing to me and I find it a bit off putting. Just some honest feedback. I'm excited to see where the app goes from here. 1
asgard25 54 Posted November 21, 2025 Author Posted November 21, 2025 34 minutes ago, Jdiesel said: I've been using the app for the past few weeks and generally I do like having information in one location. My only complaint is that the app is becoming a bit spammy with notifications, especially since I have notifications disabled in the app itself. I'm not interested in joining the discord, raffles for premium which I already have, or other apps. Especially as a premium user. I understand being compensated for development but the store is unappealing to me and I find it a bit off putting. Just some honest feedback. I'm excited to see where the app goes from here. Hi, thanks for the feedback, I really appreciate it. The shop section is purely cosmetic and absolutely not mandatory. Feel free to suggest new ideas! I recently added Linux, Windows, and Seerr monitoring.
trashken 7 Posted November 22, 2025 Posted November 22, 2025 I changed my account password but doesn't seem to be a place to update it on the app..
asgard25 54 Posted November 22, 2025 Author Posted November 22, 2025 22 minutes ago, trashken said: I changed my account password but doesn't seem to be a place to update it on the app.. Hi! Thanks for your request, but the information provided is not clear enough to understand what you need. Could you please share more details about the issue, the expected behavior, and any relevant examples or steps to reproduce? This will help me provide an accurate and helpful answer.
GrimReaper 4894 Posted November 22, 2025 Posted November 22, 2025 37 minutes ago, trashken said: I changed my account password but doesn't seem to be a place to update it on the app.. Remove/re-add sever?
asgard25 54 Posted November 22, 2025 Author Posted November 22, 2025 (edited) @trashken Screenrecorder-2025-11-22-13-20-36-134.mp4 Edited November 22, 2025 by asgard25
GrimReaper 4894 Posted November 22, 2025 Posted November 22, 2025 13 minutes ago, asgard25 said: U can edit this edit mp4 not work? Not sure who are you replying to nor what do you mean by this? Thanks. 1
asgard25 54 Posted November 22, 2025 Author Posted November 22, 2025 (edited) 14 minutes ago, GrimReaper said: Not sure who are you replying to nor what do you mean by this? Thanks. I wanted to post a video to show him how to edit it, but it doesn't seem to be displaying. Edit: OK it's work Edited November 22, 2025 by asgard25 1
asgard25 54 Posted December 4, 2025 Author Posted December 4, 2025 Hello all, New update v1.6.REV-74 - Add reboot/stop on Linux & Windows monitored screen - Add Linux & Windows in Dashboard (can be disabled from the customization menu) - Redesigned the billing page - Added new purchase options in the app's shop: subscription or one-time purchase - Added fallback content when no data is available in the Radarr/Sonarr carousel - Added caching for the statistics screen - Increased timeout values to prevent error messages when the server takes longer to respond Have a good day!
