NikeSwe 122 Posted October 13, 2025 Posted October 13, 2025 (edited) The flag for the Swedish language in the app has the flag of El Salvador. Probably because the country El Salvador = SV and Sweden = SE. But, Swedish/Svenska, the language = SV. So, country SE, language SV. The viewing history for each user show the history for some other user, not the selected one (I already bought premium). Like if I select myself I see history for one of my kids. Same on their users. Edited October 13, 2025 by NikeSwe 1
yocker 1410 Posted October 13, 2025 Posted October 13, 2025 For me it feels very slow when typing in the server information to the point that it missed some letters and numbers. After the information has been put in there are no slowdowns i have noticed.
AndreiP 33 Posted October 13, 2025 Posted October 13, 2025 33 minutes ago, NikeSwe said: The viewing history for each user show the history for some other user, not the selected one (I already bought premium). +1 same here. 1
NikeSwe 122 Posted October 13, 2025 Posted October 13, 2025 (edited) It doesn't like if it I try use my domain (via reverse proxy). Auth failed. Internal ip works to connect to server. Edited October 13, 2025 by NikeSwe 1
averrkn0t 5 Posted October 13, 2025 Posted October 13, 2025 (edited) Does this allow Restart and Shutdown of the emby server, or is this just for monitoring? Edited October 13, 2025 by averrkn0t
asgard25 54 Posted October 13, 2025 Author Posted October 13, 2025 5 minutes ago, averrkn0t said: Does this allow Restart and Shutdown of the emby server, or is this just for monitoring? Hello both, thank you.
asgard25 54 Posted October 13, 2025 Author Posted October 13, 2025 2 hours ago, NikeSwe said: The flag for the Swedish language in the app has the flag of El Salvador. Probably because the country El Salvador = SV and Sweden = SE. But, Swedish/Svenska, the language = SV. So, country SE, language SV. The viewing history for each user show the history for some other user, not the selected one (I already bought premium). Like if I select myself I see history for one of my kids. Same on their users. Hello, thank you for your feedback, it's noted. I'll check for the next update. Thank you.
averrkn0t 5 Posted October 13, 2025 Posted October 13, 2025 7 minutes ago, asgard25 said: Hello both, thank you. Thanks
ZanderKeen 73 Posted October 13, 2025 Posted October 13, 2025 (edited) On 10/10/2025 at 12:38 PM, vincen said: It's reported by DuckDuckGo tool to detect/block all trackers on Android Device. I'm curious to understand why it reports these if as you say App doesn't access these datas. How is that possible ? @vincen This is what I got running the exodus-privacy report. Exodus-privacy is the default privacy checker that shows up on de-googled android app stores like aurora store & App Lounge. https://reports.exodus-privacy.eu.org/en/reports/661150/ No location permissions detected (it does grab your unique AD_ID identifier but that's anything using Google Firebase Analytics). But I don't see anything malicious. Personally, I mostly stick with just f-droid apps to avoid Google Firebase, but that's a luxury google android users won't be able to use much longer. Edited October 13, 2025 by ZanderKeen 1 1
asgard25 54 Posted October 13, 2025 Author Posted October 13, 2025 31 minutes ago, ZanderKeen said: @vincen Voici ce que j'ai obtenu en exécutant le rapport exodus-privacy. Exodus-privacy est le vérificateur de confidentialité par défaut qui apparaît sur les boutiques d'applications Android dé-google comme Aurora Store et App Lounge. https://reports.exodus-privacy.eu.org/fr/reports/661150/ Aucune autorisation de localisation détectée (votre identifiant AD_ID unique est récupéré, mais cela ne concerne pas Google Firebase Analytics). Cependant, je ne vois rien de malveillant. Personnellement, je m'en tiens principalement aux applications f-droid pour éviter Google Firebase, mais c'est un luxe que les utilisateurs de Google Android ne pourront plus utiliser très longtemps. Hello Thanks for your feedback. You can disable analytics in the application settings 1
WilhelmStroker 107 Posted October 13, 2025 Posted October 13, 2025 This looks decent, and I like the sonarr and radarr integration. 3 points: the icon is jellyfin, I guess because the app was initially written for jellyfin. Overseerr integration would be great. And already mentioned, access through a reverse proxy does not work.
asgard25 54 Posted October 13, 2025 Author Posted October 13, 2025 18 minutes ago, WilhelmStroker said: This looks decent, and I like the sonarr and radarr integration. 3 points: the icon is jellyfin, I guess because the app was initially written for jellyfin. Overseerr integration would be great. And already mentioned, access through a reverse proxy does not work. Hello, where is there a jf icon?
WilhelmStroker 107 Posted October 13, 2025 Posted October 13, 2025 the icon used for the app shows a jellyfish which is a bit close to jellyfin (and i think jellyfin's name was based on jellyfish). Plus I have both jellywatch and embywatch installed and even though the icons are different colour, they look pretty similar.
marriedman 85 Posted October 13, 2025 Posted October 13, 2025 11 hours ago, ZanderKeen said: Personally, I mostly stick with just f-droid apps to avoid Google Firebase, but that's a luxury google android users won't be able to use much longer. From what little I have read, this will only affect those that are on OEM or vendor ROM's. If you are on a custom ROM, you are OK for now. However, Google has made a lot of progress sabotaging 3rd party developers that this may not be true for long. PostmarkOS is looking better and better everyday. If Lineage has to dump Android in the future, maybe they will segue to that.
asgard25 54 Posted October 13, 2025 Author Posted October 13, 2025 @NikeSwe @AndreiP Which server version are you using?
AndreiP 33 Posted October 13, 2025 Posted October 13, 2025 1 minute ago, asgard25 said: @NikeSwe @AndreiP Which server version are you using? Version 4.9.1.80 on Windows PC. 1
asgard25 54 Posted October 13, 2025 Author Posted October 13, 2025 8 minutes ago, AndreiP said: Version 4.9.1.80 on Windows PC. Would you like to join the beta project to try a newer version to check the historical user list? If so, please send me your email in a private message. Thank you.
Troymz 2 Posted October 13, 2025 Posted October 13, 2025 (edited) 1 hour ago, asgard25 said: Would you like to join the beta project to try a newer version to check the historical user list? If so, please send me your email in a private message. Thank you. Edited October 13, 2025 by Troymz 1
SikSlayer 254 Posted October 14, 2025 Posted October 14, 2025 Just installed and bought the premium. I'm liking what I'm seeing already. If you need another beta tester, I'm down if you are... just need to find the Discord link. 1 1
NikeSwe 122 Posted October 14, 2025 Posted October 14, 2025 2 minutes ago, SikSlayer said: Just installed and bought the premium. I'm liking what I'm seeing already. If you need another beta tester, I'm down if you are... just need to find the Discord link. Discord button in the app. 1 1
asgard25 54 Posted October 14, 2025 Author Posted October 14, 2025 3 hours ago, SikSlayer said: Just installed and bought the premium. I'm liking what I'm seeing already. If you need another beta tester, I'm down if you are... just need to find the Discord link. 1
asgard25 54 Posted October 15, 2025 Author Posted October 15, 2025 Hello, are other people experiencing inconsistencies in the user statistics history?
Normanos 13 Posted October 17, 2025 Posted October 17, 2025 Tried to login via reverse proxy: "bla bla bla" app says "You been banned from server permanently" Local IP works fine.
asgard25 54 Posted October 17, 2025 Author Posted October 17, 2025 1 hour ago, Normanos said: Tried to login via reverse proxy: "bla bla bla" app says "You been banned from server permanently" Local IP works fine. Hello, The app itself does not handle user authentication directly. It simply uses the Emby API to perform the login. If you see the message “You’ve been banned from the server permanently” only when connecting through a reverse proxy (while the local IP works fine), this indicates that the issue comes from the Emby server or its network configuration, not from the app itself. I recommend checking the reverse proxy settings or any ban rules configured on your Emby server.
