noinch 2 Posted October 13, 2025 Author Posted October 13, 2025 I did try. Same result... Updating then timed out
sa2000 695 Posted October 13, 2025 Posted October 13, 2025 (edited) 2 hours ago, noinch said: did try. Same result... Updating then timed out So installing any other app hangs in the same way. Can you approach WD support / use WD forums if the issue is not specific to Emby Edited October 13, 2025 by sa2000 mentioned synology instead of Western Digital !
sa2000 695 Posted October 13, 2025 Posted October 13, 2025 I don't know if you have already run system diagnstic tests - this Western Digital support doc covers checking the drives https://support-en.wd.com/app/answers/detailweb/a_id/30057/
