Bart91106 2 Posted October 8, 2025 Posted October 8, 2025 How can I turn OFF the new default of combining movies versions into one. I understand that I can do this manually for within the "combined" movie screen, but this is cumbersome. Is there a way to turn this default OFF? Thanks!
GrimReaper 4926 Posted October 8, 2025 Posted October 8, 2025 3 hours ago, Bart91106 said: Is there a way to turn this default OFF? Disable it in library settings.
Bart91106 2 Posted October 8, 2025 Author Posted October 8, 2025 I did and restarted server. It did not work.
GrimReaper 4926 Posted October 8, 2025 Posted October 8, 2025 (edited) 3 hours ago, Bart91106 said: I did and restarted server. It did not work. What do you mean by it didn't work? What were you expecting would occur that did not? Edit: Have you ran Scan media library task? Edited October 8, 2025 by GrimReaper Append
Luke 42289 Posted October 8, 2025 Posted October 8, 2025 17 minutes ago, Bart91106 said: I did and restarted server. It did not work. Hi, did you make sure to read the help text at the top of the library options dialog?
Solution Bart91106 2 Posted October 9, 2025 Author Solution Posted October 9, 2025 I initially did this I did this via the Android app. However, I went to the my server on Windows after your post. I saw the "notice" help text in the library options. I reselected not to group versions. I'm now rescanning the metadata. Thanks for your input! 1
