Pkanarki 2 Posted October 8, 2025 Posted October 8, 2025 Hi I have been using the old Android TV app on my shield TV for years now. Only thing holding me back from switching to the new android app is opening the TV guide WHILE watching a live TV program with my remote requires ONE remote button press on the Android TV app vs 5-6 button presses on the new android app?!? Have I missed a setting? Or will this be changed? Best regards
Luke 42241 Posted October 10, 2025 Posted October 10, 2025 Hi, what button would you like to open it with?
Solution pünktchen 1411 Posted October 10, 2025 Solution Posted October 10, 2025 How about to make the live tv guide also an option for long press okay and button up?
ebr 16334 Posted October 10, 2025 Posted October 10, 2025 The TV app used "up" because there are no chapters in Live TV and the guide seemed the most likely thing people wanted quick access to but configurable on those other actions would probably be even better.
Pkanarki 2 Posted October 10, 2025 Author Posted October 10, 2025 4 hours ago, pünktchen said: How about to make the live tv guide also an option for long press okay and button up? I agree. Why not just make it the same as the android TV app.
Luke 42241 Posted October 22, 2025 Posted October 22, 2025 We could make the up action option chapters / guide so that it opens chapters for content with chapters, and otherwise the guide.
leem0401 4 Posted January 20 Posted January 20 Yes please. This is the only reason why I haven't made the switch. 1
Luke 42241 Posted January 20 Posted January 20 40 minutes ago, leem0401 said: Yes please. This is the only reason why I haven't made the switch. The change has already been made.
leem0401 4 Posted January 25 Posted January 25 (edited) How do I do it? I pressed up and it only brings up progress bar. When I press down, I see Info, On Now, then Guide so to get to the guide I have to press down, right, right, down. I'm on Fire TV stick so maybe it's different. Edited January 25 by leem0401
Luke 42241 Posted January 25 Posted January 25 1 hour ago, leem0401 said: How do I do it? I pressed up and it only brings up progress bar. When I press down, I see Info, On Now, then Guide so to get to the guide I have to press down, right, right, down. I'm on Fire TV stick so maybe it's different. HI, have you explored the option in the app to control the up action during video playback? 1
