A5Jose 1 Posted October 6, 2025 Posted October 6, 2025 Desde que actualice a la ultima version cuando agrego una pelicula, me actualiza los metadatos de todas y me las deja asi, solo me pasa con esa biblioteca, el resto esta bien
A5Jose 1 Posted October 7, 2025 Author Posted October 7, 2025 I have a problem with my movie library. When I scan to add a new movie, it updates the metadata for the entire library. This only happens with the movie library; with TV series and anime libraries, it doesn’t happen, and it adds the episodes while keeping the existing metadata intact. I’m using the latest version, and this didn’t happen before.
Happy2Play 9811 Posted October 7, 2025 Posted October 7, 2025 Can only guess the same issue as the other topics where movie libraries are being reset. As it sort of appear to be the changes in Folder view per some other topics.
Luke 42239 Posted October 11, 2025 Posted October 11, 2025 @A5Josehow are your files named and organized? have you completed a full library scan?
A5Jose 1 Posted October 11, 2025 Author Posted October 11, 2025 Now I’ve completed the full scan, but many of them are misidentified, and I’ll have to fix them manually because of the issue with the latest stable version. Is there any solution?
Luke 42239 Posted October 22, 2025 Posted October 22, 2025 On 10/11/2025 at 6:39 PM, A5Jose said: Now I’ve completed the full scan, but many of them are misidentified, and I’ll have to fix them manually because of the issue with the latest stable version. Is there any solution? @A5Josecan you please provide an example ? Thanks !
