Emby Connect Issue
Cyberbob2021
Hi
Sorry I am putting this in the wrong place,  I'm in the process of changing my IPS,
I have Vodaphone, and its been working fine for years, I still have Vodaphone. But am testing the 3 home broadband, %G everything is working great. so I swapped emby over to it, internal everything is great,  but when I try to connect external nothing, the server is showing a Wan address its green, but I don't think its updating connect, and I'm not sure you can port forward with these 5g routers, it seems limited, I have not dumped Vodaphone yet, hoping to get a solution, because its faster upload download than Vodaphone & half the price.  does anyone else have any experience using using 5G three home broadband & emby connect at all ?
Thanks in advance
Cyberbob2021
Thanks, again sorry was unsure.
Cyberbob2021
Solved, you can infact port forward, with 3 home broadband, & it works. so far so good. just have to log into router via a pc & not the app, dumb I should have worked that out.
  1. Access your Router: Open a web browser and go to your router's IP address (e.g., 192.168.0.1) to access the web interface.
  2. Log In: Enter your administrator username and password to log in.
  3. Locate Port Forwarding: Look for a section like "Internet," "Security," "Advanced," or "Firewall" and select "Port Forwarding".
  4. Create a New Rule: Click on "Create New Item" or "Add new port mapping".
  5. Enter Details:
    • Name: Give your rule a descriptive name.
    • Protocol: Choose between TCP, UDP, or both.
    • Destination IP Address: Enter the static IP address of the device you want to forward the port to.
    • WAN Port: The port you want to open from the internet to your router.
    • LAN Port: The port that the device on your local network is listening on.
  6. Apply Settings: Save your new port forwarding rule.
Hi, thanks for following up !
  • Thanks 1
Cyberbob2021
Your Welcome, Couple of notes
The 5G router I'm working with is the ZTEModel MC888A, 5G Three Home Broadband
Best advice I can give, is use a pc or MacBook to log into the router, as on ipad or iphone, the pc mode don't seem to work very well. & it wants you to use mobile mode, which is very very limited in settings, where pc mode you get all settings menu. another thing to note, YOU must be using a 5G broadband sim, if your trying to use a mobile sim in the router, the mobile network will not allow port forwarding. the is a difference between a Broadband Sim & Mobile Sim
  • Thanks 1
