njmckenzie96 3 Posted October 6, 2025 Posted October 6, 2025 On server build 4.9.1.80, media controls in notification bar (Android 16) using pause or stopped working. Emby on Google TV (all updated to lastest) will pause for a few seconds and then start up again. Using the stop button on media controls will stop the movie, and close the app, but then emby will begin playing in the background and stay that way, even though the Google TV main screen is displayed.
Abobader 3491 Posted October 6, 2025 Posted October 6, 2025 Hello njmckenzie96, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Luke 42288 Posted October 10, 2025 Posted October 10, 2025 @njmckenzie96Hi, what version number of the Emby Android app is this with?
njmckenzie96 3 Posted October 10, 2025 Author Posted October 10, 2025 Android 3.5.12. but it also was happening on previous version as well.
Solution Luke 42288 Posted November 3, 2025 Solution Posted November 3, 2025 HI @njmckenzie96are you still seeing this with Emby for Android 3.5.15 ?
njmckenzie96 3 Posted November 11, 2025 Author Posted November 11, 2025 I'd like to add now after using this update for awhile. The pause works from Android, but "stop" closes the app but it plays in the background on Chromecast; even with a movie. It appears the Chromecast sees it how it sees Spotify (allows Spotify to play in the background and shows a small screen in the home menu). @SamES
