rcsnoopdog 11 Posted October 5, 2025 Posted October 5, 2025 (edited) I have never had problems with edge before & emby , but a file I was playing yesterday will not play today - I just get the circle moving round . I have windows 10 installled , the file is 480p H264 English AC3 stereo (Default) - It plays okay on app on Samsung tv , I have all extensions switched off , this pc hosts the server with the files on external hdds I have noticed the files that are playing are hevc and the ones that have not played are h264 , but only a small selection I have tried 480p H264 English AC3 stereo (Default) embyserver (1).txt ffmpeg-transcode-5199ced7-5ee3-491d-a41f-a0b93eb206cf_1.txt ffmpeg-transcode-f1120072-b2eb-4ba6-aaee-ec8552b19f43_1.txt ffmpeg-transcode-5f56c5ce-a61c-4686-b392-40510ab1a47c_1.txt ffmpeg-transcode-b5ba74df-ba9a-44d7-960b-064597970f06_1.txt hardware_detection-63895307210.txt embyserver-63895307191.txt hardware_detection-63895306680.txt Edited October 5, 2025 by rcsnoopdog
seanbuff 1360 Posted October 5, 2025 Posted October 5, 2025 Please attach the information requested in how to report a media playback issue. Thanks!
rcsnoopdog 11 Posted October 5, 2025 Author Posted October 5, 2025 7 minutes ago, seanbuff said: Please attach the information requested in how to report a media playback issue. Thanks! embyserver (1).txt ffmpeg-transcode-5199ced7-5ee3-491d-a41f-a0b93eb206cf_1.txt ffmpeg-transcode-f1120072-b2eb-4ba6-aaee-ec8552b19f43_1.txt ffmpeg-transcode-5f56c5ce-a61c-4686-b392-40510ab1a47c_1.txt ffmpeg-transcode-b5ba74df-ba9a-44d7-960b-064597970f06_1.txt hardware_detection-63895307210.txt embyserver-63895307191.txt hardware_detection-63895306680.txt
Luke 42289 Posted October 6, 2025 Posted October 6, 2025 Hi, are you able to try Chrome to see how that compares?
rcsnoopdog 11 Posted October 6, 2025 Author Posted October 6, 2025 17 minutes ago, Luke said: Hi, are you able to try Chrome to see how that compares? it works in chrome
rcsnoopdog 11 Posted October 15, 2025 Author Posted October 15, 2025 On 06/10/2025 at 04:54, Luke said: OK we'll take a look at it. Thanks. I have not came back to this as I had to upgrade to windows 11 which has been done , but the problem with edge is still there and i noticed a new file which is not x246 but hevc and it did not work , NOT WORKING Video Title 1080i HEVC Codec HEVC Profile Main 10 Level 120 Resolution 1920x1080 Aspect Ratio 16:9 Interlaced Yes Framerate 25 Bitrate 2 mbps Colour Primaries bt709 Colour Space bt709 Colour Transfer bt709 Bit Depth 10 bit Pixel Format yuv420p10le Reference Frames 1 Audio Title English AC3 stereo (Default) Language English Codec AC3 Layout stereo Channels 2 ch Bitrate 384 kbps Sample Rate 48,000 Hz Default Yes Subtitle Title English (ASS) Language English Codec ASS Default No Forced No Hearing Impaired No External No Video Title 480p H264 Codec H264 Profile High Level 31 Resolution 704x480 Aspect Ratio 853:480 Interlaced No Framerate 23.976 Bitrate 2 mbps Bit Depth 8 bit Pixel Format yuv420p Reference Frames 1 Audio Title English AC3 stereo (Default) Language English Codec AC3 Layout stereo Channels 2 ch Bitrate 192 kbps Sample Rate 48,000 Hz Default Yes Subtitle Title English (SUBRIP) Embedded Title Closed Captions Language English Codec SUBRIP Default No Forced No Hearing Impaired No External No WORKING Video Title 1080p HEVC Codec HEVC Profile Main 10 Level 120 Resolution 1920x816 Aspect Ratio 40:17 Interlaced No Framerate 23.976 Bitrate 1 mbps Bit Depth 10 bit Pixel Format yuv420p10le Reference Frames 1 Audio Title English AAC 5.1 (Default) Language English Codec AAC Profile HE-AAC Layout 5.1 Channels 6 ch Bitrate 320 kbps Sample Rate 48,000 Hz Default Yes Subtitle Title English (Default SUBRIP) Embedded Title English Language English Codec SUBRIP Default Yes Forced No Hearing Impaired No External No If you would like me to find more just ask or anything else I can do , Thanks
Luke 42289 Posted October 15, 2025 Posted October 15, 2025 When this happens are you able to use playback correction to get it to play?
rcsnoopdog 11 Posted October 15, 2025 Author Posted October 15, 2025 (edited) playback correction, What do you mean ? 21 minutes ago, Luke said: When this happens are you able to use playback correction to get it to play? Do you mean mark played ? Edited October 15, 2025 by rcsnoopdog
Luke 42289 Posted October 15, 2025 Posted October 15, 2025 There is a button for it in the video player.
rcsnoopdog 11 Posted October 15, 2025 Author Posted October 15, 2025 3 minutes ago, Luke said: There is a button for it in the video player. It works doing that but I'm transcoding it yes
Solution Luke 42289 Posted October 16, 2025 Solution Posted October 16, 2025 3 hours ago, rcsnoopdog said: It works doing that but I'm transcoding it yes Right but the browser video player is having a problem when trying to direct play this file. Playback correction allows you to switch to transcoding so that you can at least play. Normally that would happen automatically, but sometimes there could be a situation where the video player gets stuck and doesn't actually raise an error.
