bobbee001 4 Posted October 5, 2025 Posted October 5, 2025 Moving from plex. My tv shows are all at one location, each program and season in a separate folders. H\tv\chicago fire h:\tv\chicago Pd h:\tv\chicago med with each series listed in folders below h:\tv\chicago fire\season 1 h:\tv\chicago fire\ season 2 Do I have to change this file setup for emby or am I missing a check box somewhere ?
bobbee001 4 Posted October 5, 2025 Author Posted October 5, 2025 Disregard, it works fine. Been on PLEX for years but do to their latest interface had to find something else, this emby seems great, what plex used to be.. 2
Neminem 1630 Posted October 5, 2025 Posted October 5, 2025 @bobbee001 If you run into A series that has more than 1 adaptation remember to add year and tvdbid to your folder naming. Like this TV Show Charmed. Charmed (1998) [TvdbId=70626] Charmed (2018) [TvdbId=349317]
bobbee001 4 Posted October 5, 2025 Author Posted October 5, 2025 2 issues: When you mark an episode as played, do you have to open it to tell, no mark on the icon ? When I fall a sleep at night I want the episode being watched to be it, not automatically start the next. Is that an option ?
Neminem 1630 Posted October 5, 2025 Posted October 5, 2025 (edited) 18 minutes ago, bobbee001 said: When you mark an episode as played, do you have to open it to tell, no mark on the icon ? Yes I think you need to go to that episode and mark it played or not played. 18 minutes ago, bobbee001 said: When I fall a sleep at night I want the episode being watched to be it, not automatically start the next. Is that an option ? There is this option, you can play with If that does not suite you then go to episode and play that. Playing from other places will treat it as a playlist. Edited October 5, 2025 by Neminem
tedfroop21 89 Posted October 5, 2025 Posted October 5, 2025 2 hours ago, bobbee001 said: Disregard, it works fine. Been on PLEX for years but do to their latest interface had to find something else, this emby seems great, what plex used to be.. Yeah, I ran both in parallel using a single library for a couple months before dropping plex 27 minutes ago, bobbee001 said: When you mark an episode as played, do you have to open it to tell, no mark on the icon ? When I fall a sleep at night I want the episode being watched to be it, not automatically start the next. Is that an option ? Yes they are marked. In server view and in client view. Not that I know of. It would be nice because the number of episodes varies by app. That would be a nice feature to add though.
bobbee001 4 Posted October 5, 2025 Author Posted October 5, 2025 (edited) When looking at a series for example episode 1 episode 2 episode 3 If one has been played, there is no indication, you have to open each one to see if there is a checkmark. Was hoping not to have to. Another ?, where can I specify the order of the film categories ? (I did it once but can't remember where) Edited October 5, 2025 by bobbee001 addition
howllor 28 Posted October 5, 2025 Posted October 5, 2025 Not sure what you mean, i can tell that an episode has been watched even when not checking its details. Can you show where you experience this? Here's what a season view looks like for me on mobile
Luke 42289 Posted October 5, 2025 Posted October 5, 2025 Hi, where are you seeing that there's no watched indicator? We have it pretty much everywhere.
