Ahole 17 Posted October 4, 2025 Posted October 4, 2025 Any idea how I could have had this to happen? See the Background art is missing form the system items -- Movies and Collections. ?? Also I had a Portainer disaster and completely lost my docker compose file (WORD TO THE WISE --- backup ALL your Portainer compose files!!) I recreated my compose file (basically from memory) Anyone see any blaring missing items? It seems to be working, eccept for the missing "system" item artwork --- services: emby: image: emby/embyserver:beta container_name: emby labels: - com.centurylinklabs.watchtower.monitor-only=true environment: - UID=1000 - GID=100 - TZ=America/New_York network_mode: host volumes: - /DATA/AppData/EmbyConfig:/config - /mnt/192.168.1.144/CromBackup:/crombackup - /mnt/data:/data - /mnt/data/media/movies:/movies - /mnt/data/media/tv:/tvshows - /mnt/channels-dvr:/channels-dvr - /mnt/data/NewEmmBackup:/backup ports: - 8096:8096 - 8923:8920 #optional devices: - /dev/dri:/dev/dri #optional restart: unless-stopped
Luke 42242 Posted October 4, 2025 Posted October 4, 2025 Hi, try using the image editor to delete the existing images. Then run a library scan and see if that helps create new ones. Please let us know how that goes. Thanks. 1
Ahole 17 Posted October 6, 2025 Author Posted October 6, 2025 (edited) On 10/4/2025 at 7:26 PM, Luke said: Hi, try using the image editor to delete the existing images. Then run a library scan and see if that helps create new ones. Please let us know how that goes. Thanks. All good now -- Thanks Word to the wise (when using Portainer) -- BACKUP your docker compose files -- sounds simple , but can save heartache! Edited October 6, 2025 by Ahole 1
