ebr 16332 Posted October 5, 2025 Posted October 5, 2025 11 hours ago, Edrock200 said: Generally speaking how long is the turn around historically between submitting and app and it getting published to the Roku store? The update will go out Monday night. Roku does not work weekends. 2
Cyberbob2021 13 Posted October 5, 2025 Posted October 5, 2025 27 minutes ago, ebr said: Hi. Please check your PMs on this forum. I sent you a message yesterday. Thanks EBR added the beta will confirm if it works or not and will add to my system. replied to the message also. thanks
Cyberbob2021 13 Posted October 5, 2025 Posted October 5, 2025 3 hours ago, ebr said: The update will go out Monday night. Roku does not work weekends. In that case I can also wait, I thought ages, will this also fix the stream bar ? Here is the update, for me its really only the stream bar that's a real issue, and on roku premiere . which is the back up for the streambar UPDATE AS Promised, thanks for beta use. Biggest issue for me is stream bar, which is my main app no longer works no matter what. My Emby Server is Running 4.9.1.80 1) Stream bar 9102EU, 15.0.4 Build 5531 Emby icon on screen of home,. click goes to load returns to home. Beta has not appeared on stream bar menu. rebooted a few times 2) Roku Premiere 3920EU ,14.6.4 Build 9915 Can only see beta on menu, & appears to work fine, I can only see the old shortcut if I search for emby, then I can run it. 3) Roku Express 3930EU , 14.6.4 Build 9914 Unaffected Both the Original App & Beta is on home, both Work. 4) Roku StreamStick + 3810EU, 14.6.4 Build 9914 Unaffected Both the Original App & Beta is on home, both Work. 5) Roku Streamstick + 3810EU, 14.6.4 Build 9914 Unaffected Both the Original App & Beta is on home, both Work. 6) Roku Express 4k 3940EU2, 14.6.4 Build 9915 (BRAND NEW JUST SET UP) Unaffected Both the Original App & Beta is on home, both Work. 7) Mother in laws is an express, but no idea of version ect atm. but they called with emby gone from home, id have to dig deeper if more info required. Hope this helps, for me the sound bar is my main hence affected worse as complete loss till backup stick plugged in. & its my main tv.
DLGoonerGamer 0 Posted October 7, 2025 Posted October 7, 2025 I see that this was resolved on Saturday by the Emby team, but as of yet I've seen no update and my Emby app still keeps crashing.
Edrock200 53 Posted October 7, 2025 Posted October 7, 2025 1 minute ago, DLGoonerGamer said: I see that this was resolved on Saturday by the Emby team, but as of yet I've seen no update and my Emby app still keeps crashing. A few posts ago they noted Roku will push the app tonight.
NortherNerd 3 Posted October 7, 2025 Posted October 7, 2025 Thank you, Build 50 became available tonight and it is working well 2
