ginyezus 0 Posted October 3, 2025 Posted October 3, 2025 (edited) these are the logs i get please i need help ffmpeg-transcode-421c64f9-ae42-46d2-92cf-d5479baf6ae6_1.txt Edited October 3, 2025 by ginyezus
GrimReaper 4896 Posted October 3, 2025 Posted October 3, 2025 (edited) Not that you've been very descriptive about your issue, but with this error: Quote 13:57:19.390 /tv55/Succession.S01.COMPLETE.1080p.AMZN.10bit.DDP.5.1.x265.[HashMiner]/Succession.S01E08.1080p.AMZN.10bit.DDP.5.1.x265.[HashMiner].mkv: No such file or directory playback can hardly be successful. How to Report a Problem Edited October 3, 2025 by GrimReaper Link
rekit 16 Posted October 3, 2025 Posted October 3, 2025 have you rebooted your server machine (not just restarted emby, but actually rebooted the machine the emby server is running on). i get this error every few months, and that tends to solve it.
Luke 42242 Posted October 3, 2025 Posted October 3, 2025 Is your /tv55 mount offline, or did the file change?
ginyezus 0 Posted October 3, 2025 Author Posted October 3, 2025 2 minutes ago, Luke said: Is your /tv55 mount offline, or did the file change? No its still there i can see it and open the files what do you mean by offline because i have other drives and their shows work good
ginyezus 0 Posted October 3, 2025 Author Posted October 3, 2025 30 minutes ago, rekit said: have you rebooted your server machine (not just restarted emby, but actually rebooted the machine the emby server is running on). i get this error every few months, and that tends to solve it. I tried to it didn’t work it works when i downgrade the version and the update but it works for a couple hours and goes back
Luke 42242 Posted October 3, 2025 Posted October 3, 2025 13 minutes ago, ginyezus said: No its still there i can see it and open the files what do you mean by offline because i have other drives and their shows work good Well to the server it looks like that file is not there. It could be that it's not there, or it could be that the server is being denied access to it.
sa2000 697 Posted October 3, 2025 Posted October 3, 2025 Is /tv55 a mount or a sub-directory and the path is wrong? What does this show in a linux session cd /tv55 ls -ail just double checking
ginyezus 0 Posted October 6, 2025 Author Posted October 6, 2025 On 10/3/2025 at 9:08 PM, sa2000 said: Is /tv55 a mount or a sub-directory and the path is wrong? What does this show in a linux session cd /tv55 ls -ail just double checking its a sub directory the path is an external drive
sa2000 697 Posted October 6, 2025 Posted October 6, 2025 So the commands i suggested do work and return a listing ? cd /tv55 ls -ail
ginyezus 0 Posted October 6, 2025 Author Posted October 6, 2025 12 minutes ago, sa2000 said: So the commands i suggested do work and return a listing ? cd /tv55 ls -ail it said permission denied but then i put the ls -ail it said a bunch of stuff
sa2000 697 Posted October 6, 2025 Posted October 6, 2025 On 03/10/2025 at 18:18, Luke said: it could be that it's not there, or it could be that the server is being denied access to it. may be the permissions denied error error you got is why the emby server could not see the files 11 minutes ago, ginyezus said: it said permission denied but then i put the ls -ail it said a bunch of stuff
Solution ginyezus 0 Posted October 6, 2025 Author Solution Posted October 6, 2025 24 minutes ago, sa2000 said: may be the permissions denied error error you got is why the emby server could not see the files its fixed i just chmod and gave permissions i didnt think of it cuz it just worked for months and just suddenly idk why stopped working
sa2000 697 Posted October 6, 2025 Posted October 6, 2025 great - thanks for the feedback and checking this 1
