sh0rty 727 Posted November 15, 2025 Author Posted November 15, 2025 (edited) On 11/14/2025 at 6:06 PM, Gremory17 said: The CSS is great! But the numbers look really small. Is there any way to edit them so they're more centered in the corners and larger? Algo Asi Adjust the bracket from line 451-456 regarding horizontal and vertical positioning and replace "right" with "left", when switching the side you want it to be shown. If you want it to be larger, you need to add the font-size attribute to the snippet. Here is an example for langer button + top left positioning. .cardIndicator.cardCountIndicator.CountIndicator.countIndicator { position: absolute; top: 2px; bottom: auto; left: 2px; font-size: 102% !important; } The CSS is originally intended for usage in combination with the coverart plugin. Edited November 15, 2025 by sh0rty 1
sh0rty 727 Posted February 6 Author Posted February 6 (edited) I restructured the repo a bit, bumped version and added my own JS scripts that have no own repo inside Addons folder. For everyone using this theme via import url, please use this one from now on. @import url("https://cdn.jsdelivr.net/gh/v1rusnl/Embymalism@latest/Embymalism.css"); Old css are inside Archive folder. https://github.com/v1rusnl/Embymalism Edited February 6 by sh0rty 1 1
sh0rty 727 Posted February 6 Author Posted February 6 Sorry, wrong URL. @import url("https://cdn.jsdelivr.net/gh/v1rusnl/Embymalism@main/Embymalism.css");
sh0rty 727 Posted February 10 Author Posted February 10 Because I updated Spotlight widget, just for the sake of completeness. If someone uses the custom rating JS snippet from inside the GH repo, Oscar Wins/Nominations via Wikidata SPARQL API are also added to the rating JS on detail screen. 1
sh0rty 727 Posted February 10 Author Posted February 10 And Emmy Wins/Nominations via Wikidata SPARQL API also here.
sh0rty 727 Posted February 11 Author Posted February 11 (edited) Added Golden Globes Wins/Nominations via Wikidata SPARQL API + show trophys instead of text to emby.ratings.js in Addons folder. The results are just as good as the data in wikidata, anyone can contribute. Edited February 11 by sh0rty
