sbrindley 3 Posted May 18, 2017 Posted May 18, 2017 Would be a great idea on a per-user basis, to have the option within the users "access tab" to limit the logins to "X" logins and also having an "unlimited logins" option. I have a few friends that have connected on several devices and sometimes they're logged in from their tablet, computer (browser) and also from a media device like Roku, yet they're only using one device... However, some have been streaming from multiple devices too. It is a bit of a hassle at times. Keep up the great work on EMBY and thanks!!
c.adr75 3 Posted June 1, 2017 Posted June 1, 2017 Friends would have news about this update of paramount importance? Well in my case being a premiere user and I'm sure many others who are also have a huge need because without it users send their password to several people not authorized by us causing a great financial loss, consuming too much our internet bandwidth.
chef 3811 Posted June 2, 2017 Posted June 2, 2017 (edited) Friends would have news about this update of paramount importance? Well in my case being a premiere user and I'm sure many others who are also have a huge need because without it users send their password to several people not authorized by us causing a great financial loss, consuming too much our internet bandwidth. I put a disclaimer in the bottom of my login page with CSS prohibiting password sharing, then I monitor the IP address daily and look for ones which might seem odd. Obviously ddyns is a thing... I don't have many users so it doesn't take much time. Edited June 2, 2017 by chef
horstepipe 423 Posted June 2, 2017 Posted June 2, 2017 then I monitor the IP address daily and look for ones which might seem odd can you recommend some tool for monitoring or do you only use the Emby WebGUI?
chef 3811 Posted June 2, 2017 Posted June 2, 2017 can you recommend some tool for monitoring or do you only use the Emby WebGUI? Yeah emby dashboard. Just looking at the right side panel which shows login info, and the IP address are listed right under the user name.
c.adr75 3 Posted June 2, 2017 Posted June 2, 2017 I put a disclaimer in the bottom of my login page with CSS prohibiting password sharing, then I monitor the IP address daily and look for ones which might seem odd. Obviously ddyns is a thing... I don't have many users so it doesn't take much time. Chef thank you for the information, but I have many registered users, it would be unfeasible for me to be monitoring all of them, it would be easier and I practice an appropriate tool for this.
chef 3811 Posted June 2, 2017 Posted June 2, 2017 I haven't seen anything in the API which returns session IP address, only session info about client and DeviceName. However, even if you could figure out rogue devices attached to your sever, there currently isn't anyway to boot their connection. You could use the DLNA to cancel playback, but technically they could just start it again.
pir8radio 1313 Posted June 3, 2017 Posted June 3, 2017 (edited) can you recommend some tool for monitoring or do you only use the Emby WebGUI? This wont do you much good if a user connects via IPv6. The internet facing IPv6 address is randomly generated by most OS's to protect the privacy of surfing users. See first image below where I log into my own server. But if you are IPv4 only then this can work. Chef thank you for the information, but I have many registered users, it would be unfeasible for me to be monitoring all of them, it would be easier and I practice an appropriate tool for this. Just like any web server, you analyze the logs.. I run my emby behind NGINX and then use a normal web log analyzer to turn it into something usable. You can use splunk to alert you of concurrent logins from different IP's as well. Below are a few images of my "user stats". Me logging into my server, OS gives random IPv6 addresses: Stats you can generate using nginx as a front end: Users and the IP's/HOSTS they use to connect to your server: User stats (all kinds of cool stats, but this one shows logins): Edited June 3, 2017 by pir8radio 2
legallink 187 Posted August 16, 2017 Posted August 16, 2017 My assumption is simultaneous logins. The ability to have more than x number of concurrent streams associated with one user id 1
pir8radio 1313 Posted August 16, 2017 Posted August 16, 2017 (edited) My assumption is simultaneous logins. The ability to have more than x number of concurrent streams associated with one user id That is two different things, I think that's why he is asking... I think your first statement is how I read the request.. "simultaneous logins". I could see it working like: If i set this user to only "1" that means that user will be issued a login token, when that same user tries to login a second time, he gets an error possibly asking if they would like to disconnect the other user (like pandora) and the first token is revoked. If this setting is set to "2" then two login tokens are given out. If you just block the second login first logins that are hung-up will prevent a legitimate user from logging in, which is why I would suggest a pandora like booting of one of the other users. Both options will upset people, I think this might be a tough one to work out.. lol The second part of your message would mean that 20 of the same user could login but only X could stream, I can see that being a nightmare to code especially with mp3 (music) streams and direct streaming. But I'm just assuming as well..... Edited August 16, 2017 by pir8radio 1
darkassassin07 674 Posted August 16, 2017 Posted August 16, 2017 Personally I would want this to limit the number of connections able to get past the login screen at a time: set to 1, one person could log into a single session and browse/play media. While that session is still connected anyone else that attempts to use the same credentials at login gets an error, possibly the option to disconnect the oldest active session when that error appears.
Soki 9 Posted August 16, 2017 Posted August 16, 2017 I find this feature is an important one... a MUST have. I too experienced dual streaming through one account via different browsers which i do not like at all due to many reasons. If you give away an account to a friend for example and this dude (maybe even by accident) gives away this logindata to others, that is a serious problem and could cause a series of problems.... There MUST be a way to control this directly via emby. So a big big big +1 from me to this feature. There should be a way to limit logins to 1 per account! Even better would be if there where options like "limit login to 1 per account" and "limit streaming to 1 per account". Thanks Soki
pir8radio 1313 Posted August 16, 2017 Posted August 16, 2017 A setting in the user would be the way to go, Not server wide. For example my parents have one account, but my mother might watch on roku, and my father might not like what she is watching and he will go in another room and watch something. So I wouldn't want to limit their account... Or when I have a guest account enabled, I wouldn't want to limit that. So a field within the user settings that defaults to 0 (unlimited) that we can change to X would be the best bet IMO. 2
PremiumRed 69 Posted August 24, 2017 Posted August 24, 2017 +1 Yeah it would be something that only allows X numbers of users to login at one time
ebr 16339 Posted August 24, 2017 Posted August 24, 2017 +1 Yeah it would be something that only allows X numbers of users to login at one time Actually, that is not what this request is for. This request is to limit the number of connections for a particular user ID - not the number of users that can be connected to the server.
PremiumRed 69 Posted August 24, 2017 Posted August 24, 2017 Even better then... the important thing here is that they cant share there username and password and have 200 users connected at once with the same user id.. So +100 for that haha
Makandal 1 Posted September 14, 2017 Posted September 14, 2017 (edited) I was thinking of upgrading to Emby premiere but after reading this thread I think I wait till this is solved. 1 connection per user at a time be the perfect solution for many here I think. Very easy if the user wants to connect from a different device then let him first log off the one device being used and after that he should log into the other one. Sent from my SM-J510FN using Tapatalk Edited September 14, 2017 by Makandal 1
legallink 187 Posted September 14, 2017 Posted September 14, 2017 (edited) A setting in the user would be the way to go, Not server wide. For example my parents have one account, but my mother might watch on roku, and my father might not like what she is watching and he will go in another room and watch something. So I wouldn't want to limit their account... Or when I have a guest account enabled, I wouldn't want to limit that. So a field within the user settings that defaults to 0 (unlimited) that we can change to X would be the best bet IMO. I think, in general, if you limit the number of logins per user (and really I would assume we mean limiting the number of active devices), it for the most part by its nature, would limit the number of concurrent streams. The exception to that would be if someone opened (for instance) multiple tabs in one browser sessions and streamed multiple things at the same time. From my perspective I would take that as an acceptable outlier to the solution. Edited September 14, 2017 by legallink
