Wijnand 1 Posted October 1, 2025 Posted October 1, 2025 Sorry if this was asked before, but i couldn't find it. I just don't know how to fix this. Left album has 16 tracks with track 9 missing. Right album only has track 9 into it. Track 9 should be inside the left album so that there's only one album left. I have checked all files with Mp3tag and all is good. Can someone explain to me how to move track 9 from one album to the other?
Neminem 1591 Posted October 1, 2025 Posted October 1, 2025 mp3tag can tell you whats up. Check each track and compare musicbrainz id's to get it settled. Emby only used metadate to identify.
Luke 42176 Posted October 1, 2025 Posted October 1, 2025 Hi, the tracks should all have the same album and album Artist values.
Solution Wijnand 1 Posted October 1, 2025 Author Solution Posted October 1, 2025 As far as i know all tracks were tagged with MusicBrainz as tag source. So i moved the folder and files out of the library, scanned the library, moved the folder and files back into the library and scanned it again. Now all is good. Did this same thing with some others CD's that were having the same issue and it worked like a charm. 1
