WALTERDISNEY 0 Posted October 1, 2025 Posted October 1, 2025 Hi, Windows 11 user here. I have been using the software for approx 2 weeks now and absolutely love it. Today, I've just encountered my first problem. I can't play a mkv-file "SHREK 2001 2160p BluRay HVEC" that I just downloaded, but seemed to work on the beta. I had an old folder with the beta or 4.8.11.0, i don't remember which. But when i went back for newest version and back to the beta it had updated sadly. I will from now on backup my server I have attached some log files, that i hope will help. ffmpeg-transcode-19bfc232-6e79-4b71-ab14-db3d921b8e9f_1.txt ffmpeg-transcode-793ff3bf-1ad9-4626-825a-b707973ed2f6_1.txt ffmpeg-transcode-931c881a-009a-449a-a419-20cbe757d98f_1.txt ffmpeg-transcode-3137ff98-e722-4bd9-8044-d5528c06befa_1.txt ffmpeg-transcode-9355a196-bcba-48be-95ab-3c4822374768_1.txt ffmpeg-transcode-3360267c-f215-4d67-8388-b063c4037338_1.txt ffmpeg-transcode-4068159e-2816-4957-bddc-07610a505351_1.txt ffmpeg-transcode-acfb1938-41da-48ed-9510-270463427eef_1.txt ffmpeg-transcode-fc0944ab-c6fd-4470-9890-775258555a83_1.txt embyserver.txt
Abobader 3491 Posted October 1, 2025 Posted October 1, 2025 Hello WALTERDISNEY, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
GrimReaper 4926 Posted October 1, 2025 Posted October 1, 2025 I've just checked your first and last logs, there's some mixup with your item paths: Quote 2025-10-01 11:35:56.522 "Path":"W:\\Seed\\Film\\Shrek.2001.DK.2160p.BluRay.x265-GUWLIX\\Shrek.2001.DK.2160p.BluRay.x265-GUWLIX - custom.mkv" Quote 2025-10-01 11:35:59.713 "Path":"G:\\Seeding\\Shrek.2001.DK.2160p.BluRay.x265-GUWLIX\\Shrek.2001.DK.2160p.BluRay.x265-GUWLIX - custom.mkv" First one failed to play: Quote 11:35:56.631 W:\Seed\Film\Shrek.2001.DK.2160p.BluRay.x265-GUWLIX\Shrek.2001.DK.2160p.BluRay.x265-GUWLIX - custom.mkv: No such file or directory 11:35:56.631 EXIT Second one played until exited: Quote 11:36:01.685 [segment @ 000002968565ec00] Opening 'G:\cache\transcoding-temp\BB9730\BB9730_10.ts.tmp' for writing 11:36:01.790 [q] command received. Exiting You'll need to clarify your setup and chain of events.
WALTERDISNEY 0 Posted October 1, 2025 Author Posted October 1, 2025 I moved the folder to G:/seeding since this is an m.2 980pro I was just testing If it was due to slow HDD(W:). It would play once, but only running the website, my tv won't run converted or native file. Native file doesn't work either way, just loads forever to come up with a message i think it says: PLAYER_ERROR_CONNECTION_FAILED Samsung TV AU9075 Tizen on this tv it always fails to play. embyserver (1).txt ffmpeg-directstream-31128258-7354-4e49-8413-c227c52f8fd9_1.txt ffmpeg-transcode-42e40593-aaa8-46f4-9ad8-b6bb74c7ac39_1.txt
GrimReaper 4926 Posted October 1, 2025 Posted October 1, 2025 3 hours ago, WALTERDISNEY said: Samsung TV AU9075 Tizen on this tv it always fails to play. @SamES
WALTERDISNEY 0 Posted October 1, 2025 Author Posted October 1, 2025 After clicking play it loaded for like 3 minutes before showing the player and gave info about movielength. It shows me the normal player but doesn't let me press play... before recieving this message "PLAYER_ERROR_GENERIC player:idle" def these words might not be in order - message only pop up for a brief second. ffmpeg-transcode-e48bc6ae-8286-414c-a142-14a176342b31_1.txt
WALTERDISNEY 0 Posted October 1, 2025 Author Posted October 1, 2025 5 minutes ago, Luke said: Hi, can you try rebooting your machine? I’ve tried that :// Taskmanager says uptime is 3 hours atm It might be the soundtrack. The Danish audiotrack in both formats (AAC/AC3) won’t load. But the DTS, which my tv doesn’t support, runs perfectly with the english language, but that doesn’t feel right and nostalgic to me. the audiofile is fine, VLC runs the file without any issue. And this was possible before the update
SamES 1088 Posted October 1, 2025 Posted October 1, 2025 7 hours ago, WALTERDISNEY said: I’ve tried that :// Taskmanager says uptime is 3 hours atm It might be the soundtrack. The Danish audiotrack in both formats (AAC/AC3) won’t load. But the DTS, which my tv doesn’t support, runs perfectly with the english language, but that doesn’t feel right and nostalgic to me. the audiofile is fine, VLC runs the file without any issue. And this was possible before the update This bit confuses me. The file in your logs only has a single AAC Danish track. Can you please do a fresh test? First, enable debug logging on the server. Then restart the server. Do the test, then please send the server and any ffmpeg logs from the time of the test. You can then turn debug logging off again. Thanks. As a note, if you are modifying files, removing tracks, renaming/moving files etc, make sure you either metadata refresh or even better to rescan the library before playback otherwise they server is working on incorrect information
