xnappo 1611 Posted December 2, 2014 Author Posted December 2, 2014 (edited) @@Luke - fine with me. @ - I haven't tested the latest as I was out of town, will post some numbers tonight. At a high level though, Fast Movies 2 is good, Fast Movies 1, not good That is before the server change though - so I am hoping that will change things. xnappo Edited December 1, 2014 by xnappo
Luke 42234 Posted December 2, 2014 Posted December 2, 2014 The dev build will be posted in the alpha area shortly. http://mediabrowser.tv/community/index.php?/topic/14710-305448/
Luke 42234 Posted December 2, 2014 Posted December 2, 2014 should we just merge these threads http://mediabrowser.tv/community/index.php?/topic/13880-fast-data-proof-of-concept/ seems like they're both discussing the same thing.
dark_slayer 103 Posted December 2, 2014 Posted December 2, 2014 @@Luke - fine with me. @ - I haven't tested the latest as I was out of town, will post some numbers tonight. At a high level though, Fast Movies 2 is good, Fast Movies 1, not good That is before the server change though - so I am hoping that will change things. xnappo I'm wondering if there is a non-ram non-pagefile location the cache could be written. I should have been reporting memory usage this whole time, but on my OE box I have 2GB ram. I'll fire it up and at least show the usage with a reasonably cached db Once you cross the available memory threshold the pi performance will likely suck, and of course their is the idea that your speed improvements are destructed after each reboot I know other addons make use of a "storage location for downloads" but I'm not sure how. I'm thinking of Youtube, Icefilms, Mashup, etc off hand
xnappo 1611 Posted December 2, 2014 Author Posted December 2, 2014 @@dark_slayer - we aren't talking all that much memory. My whole movie collection is only 2MB - you can see the size of your collection by looking for the largest file in addon_data/plugin.video.xbmb3c/cache. @ - I used a stopwatch on the Pi - it is still a lost cause but interesting as a worst-case scenerio. The profile kept crashing on me - I am almost out of space on the SD card. All Movies no cache: 158 seconds/cache 134 seconds Fast Movies no cache: 64 seconds/ cache 48 seconds Fast Movies 2: cache na: 26 seconds My collection is about 600 movies. I think my SD card may be really slow - I may try with a faster one... xnappo 1
xnappo 1611 Posted December 2, 2014 Author Posted December 2, 2014 @@Luke - sorry should have said - still stable. Playing with dev now. xnappo
dark_slayer 103 Posted December 2, 2014 Posted December 2, 2014 Failed to mention my tests were all with beta server release
e123enitan 276 Posted December 2, 2014 Posted December 2, 2014 (edited) Android box detail specs inside log record repo v.9.725 All Movies Total Download :52:51:33 (Number of Movies 1988, 142 pages) Fast All Movies: no time populated, but took a while before list drop's Fast All Movies 2: Error Script Fails However, I logged the process hope this helps, pls confirm Edited December 2, 2014 by e123enitan
dark_slayer 103 Posted December 2, 2014 Posted December 2, 2014 Android box detail specs inside log record repo v.9.725 All Movies Total Download :52:51:33 (Number of Movies 1988, 142 pages) I didn't quite understand the times you have listed. Was that 52 seconds, then 51, and then 33? Have you tried running a dedicated SSID from your router called Media5G or something similar and fixing it to 5GHz with a 40MHz channel? Your N10 should have much better server-client performance that way
xnappo 1611 Posted December 2, 2014 Author Posted December 2, 2014 @@Luke - I tried the dev server - definitely *much* smaller data. The data was <1/2 the size just as is, then removing the images was <1/4 the original size. Unfortunately my Pi was acting up and I ran out of time to benchmark. It was marginally faster on my main machine, but it tears through this stuff anyway. I will get more data from the Pi and hopefully my old Atom laptop tonight. Thanks,Chris 1
e123enitan 276 Posted December 4, 2014 Posted December 4, 2014 I didn't quite understand the times you have listed. Was that 52 seconds, then 51, and then 33? Have you tried running a dedicated SSID from your router called Media5G or something similar and fixing it to 5GHz with a 40MHz channel? Your N10 should have much better server-client performance that way my box is hard wired to router-thx
dark_slayer 103 Posted December 4, 2014 Posted December 4, 2014 my box is hard wired to router-thxOkay . . . I just assumed we were talking about the log file you had posted. I thought it said Nexus 10 Still didn't totally understand times either
e123enitan 276 Posted December 5, 2014 Posted December 5, 2014 Okay . . . I just assumed we were talking about the log file you had posted. I thought it said Nexus 10 Still didn't totally understand times either Yes it does shows as Nexus, I think for the purpose of Google play store download/recognition Finless Bob Rom in my box mirrored certain Nexus code hope it helps
