howllor 28 Posted September 30, 2025 Posted September 30, 2025 I need some help figuring out SSL for emby. I am behind CGNAT and I use a custom domain pointed at a VPS with Pangolin to tunnel traffic to my local machine. My VPS comes with an SSL certificate, and it's worked automatically for the other services I use the tunnel for (jellyseerr).
howllor 28 Posted September 30, 2025 Author Posted September 30, 2025 I found where to download a pfx file from my VPS host and submitted that to emby. The HTTPS connection still isn't working
Luke 42176 Posted September 30, 2025 Posted September 30, 2025 @howllor Hi there, please attach the Emby server log from when the problem occurred: How to Report a Problem Thanks!
howllor 28 Posted September 30, 2025 Author Posted September 30, 2025 I dont know how to specify when the problem "occurred". I guess i can remove the cert and then add it again and get the log from that?
Luke 42176 Posted September 30, 2025 Posted September 30, 2025 14 minutes ago, howllor said: I dont know how to specify when the problem "occurred". I guess i can remove the cert and then add it again and get the log from that? HI, yes please and thanks.
Solution howllor 28 Posted October 3, 2025 Author Solution Posted October 3, 2025 Turns out I had not properly deactivated the previous tunneling solution I was using, so traffic still went through that tunnel instead of my secure Pangolin tunnel. Everything is fine now lol 1
