I need help, I didn't find it myself
GrimReaper
Message added by GrimReaper,
Note to members:
No further assistance will be allowed/provided in the topic until additional clarification is obtained.
Thanks.
In the first one, I did not find changing the language or removing it. On the second, I would like to add social buttons also did not find :( I will be very grateful
To remove the top heading you could try this:
h1.viewTitle {
display: none;
It worked for me, but your page layout and naming looks slightly different to mine.
With the social media buttons (AFAIK) you cannot add elements to a page with just CSS alone.
@user24  Thank you very much, is there another way to make it slightly lower in the center?
GrimReaper
@emLmSx
Are you trying to run commercial server? What is this:
Edit: You have also been asked a question by a moderator here, what would be legitimate use of such plugin for average home user?
Edited by GrimReaper
Append
  • Like 1
3 hours ago, GrimReaper said:
@emLmSx
Can't you put buttons here? Thank you
GrimReaper
A button that literally says "Tariffs"?
of such button on server for family & friends?
So it's forbidden to put it, I'll delete it then thank you for warning
GrimReaper
Emby is a personal, non-commercial server platform, which you might share with family and friends if you chose so. Any commercial usage is in direct breach of Terms of Service and such usage will not be facilitated in any way, shape or form on official forums.
Consider this your last warning.
I forgive my requests, thank you
