tmurphy2792 29 Posted September 27, 2025 Posted September 27, 2025 It looks like my local nbc station has changed around some of it's subchannels, and subsequently the guide data has gotten broken. Zip code: 38654 Channels: 5.1 NBC - incorrect guide data (looks like this might be the guide data for 5.3?) 5.2 BOUNCE - no guide data 5.3 WMCDT3 - guide data appears correct but only has like a tiny window 5.4 OXYGEN TRUE CRIME - no guide data 5.5 365BLK - no guide 5.6 DEFY - no guide
tmurphy2792 29 Posted September 27, 2025 Author Posted September 27, 2025 Correction: Unless you guys already did something on your end apparently I'm having issues with my guide data or something. Now all the channels have guide data except 5.3
sa2000 695 Posted September 27, 2025 Posted September 27, 2025 16 hours ago, tmurphy2792 said: Now all the channels have guide data except 5.3 I can see an error in the gracenote data relating to channel 5.3 for your lineup/guide I will refer it to Gracenote. They must have been making changes and there is an error in the internal channel id info for the 5.3 Independent affiliate channel
sa2000 695 Posted September 27, 2025 Posted September 27, 2025 (edited) @tmurphy2792Actually - although I said there appears to be an error for the 5.3 relating to the details of the affiliate channel, there does appear to be a schedule for the channel covering up to 10th October. Not sure if it is right. I will refer it to Gracenote anyway Note that data gets cached for 24 hours by Emby Server. You can delete the cache and then do guide refresh - to delete the cahce, delete the files in the Emby Server data area - the contents of cache\httpclient folder Update: I am attaching the gracenote Guide channel schedule for 5.3 WMCDT3 as I see it. Let me know if it is as expected. I have adjusted the times to UTC-5 Airings for channel 5.3 Edited September 27, 2025 by sa2000
tmurphy2792 29 Posted September 27, 2025 Author Posted September 27, 2025 33 minutes ago, sa2000 said: @tmurphy2792Actually - although I said there appears to be an error for the 5.3 relating to the details of the affiliate channel, there does appear to be a schedule for the channel covering up to 10th October. Not sure if it is right. I will refer it to Gracenote anyway Note that data gets cached for 24 hours by Emby Server. You can delete the cache and then do guide refresh - to delete the cahce, delete the files in the Emby Server data area - the contents of cache\httpclient folder Update: I am attaching the gracenote Guide channel schedule for 5.3 WMCDT3 as I see it. Let me know if it is as expected. I have adjusted the times to UTC-5 Airings for channel 5.3 19.04 kB · 0 downloads Thanks, off hand I think that looks correct. At this point I'm thinking I'm having issues due to some changes I did a couple weeks ago. I run my Emby server in an unprivileged LXC inside Proxmox, a couple weeks ago when I was playing with trying to get Pluto and other free m3u sources working I blew out the LXC's storage allotment and crashed my emby server. As a preventative I went and created a sym link from /var/lib/Emby/xmltv to a new folder on an external scratch disk. Unfortunately I apparently haven't been burned by folder permissions enough times to check both the permissions of the symlink and the destination directory. So when I went to play with some XML EPGs this morning I discovered my mistake. I'm still seeing random drop ins and outs of Emby guide data for random channels though, so I might do as you suggest and just wipe that cache.
sa2000 695 Posted September 27, 2025 Posted September 27, 2025 10 minutes ago, tmurphy2792 said: Thanks, off hand I think that looks correct Thanks. I will cancel the query i referred to Gracenote
