EmilD 1 Posted September 25, 2025 Posted September 25, 2025 (edited) On 8/1/2025 at 7:23 PM, Luke said: There is now a SportsDb plugin in the Emby plugin catalog. It works with the TV content type and file naming based on the recommended file names on the SportsDb event pages. In other words, click on an event and at the bottom you will see suggested file names. I believe the entire file name gets sent to SportsDb for the lookup, which means you'll need to strictly follow these conventions or it will be unlikely to match. Enjoy. I have installed the new plugin, restared my emby. My Sports library is created as TV content. my structre in the folder is: Sports/NFL/S2025/NFL 2025-09-07 Raiders vs Patriots.mkv for example. I have set SportsDB to be the provider of metadata an images on the library. But still nothing in the new library. Any tips? Edited September 25, 2025 by EmilD
Luke 42251 Posted September 25, 2025 Posted September 25, 2025 Hi there, what exactly do you mean by "nothing in the new library" ? How to Report a Problem
EmilD 1 Posted January 14 Author Posted January 14 Well, if i create a library that is "Home videos" i can find all files that comes in the folders (for example) Sports/NFL/S2025/NFL 2025-09-07 Raiders vs Patriots.mkv But if I create a library that has the content type "TV Shows" and choose thesportsdb as source of metadata its just an empty library, nothing to be shown.
Luke 42251 Posted January 14 Posted January 14 3 hours ago, EmilD said: Well, if i create a library that is "Home videos" i can find all files that comes in the folders (for example) Sports/NFL/S2025/NFL 2025-09-07 Raiders vs Patriots.mkv But if I create a library that has the content type "TV Shows" and choose thesportsdb as source of metadata its just an empty library, nothing to be shown. How are your files named and organized?
EmilD 1 Posted January 20 Author Posted January 20 On 1/14/2026 at 2:52 PM, Luke said: How are your files named and organized? Like this: /Sport/NFL/Season 2025/NFL 2025-09-07 Washington Commanders vs New York Giants.mkv /Sport/NFL/Season 2025/NFL 2025-09-09 Chicago Bears vs Minnesota Vikings.mkv this is after the naming that appears on sportsdb: https://www.thesportsdb.com/event/2261202-chicago-bears-vs-minnesota-vikings Potential Filename https://www.thesportsdb.com/images/icons/plex.png NFL 2025-09-09 Chicago Bears vs Minnesota Vikings.mkv https://www.thesportsdb.com/images/icons/kodi.png NFL 2025-09-09 Chicago Bears vs Minnesota Vikings.S2025E1.mkv https://www.thesportsdb.com/images/icons/kodi.png (Scraper) NFL 20250909 Chicago Bears vs Minnesota Vikings.special
Luke 42251 Posted January 20 Posted January 20 30 minutes ago, EmilD said: Like this: /Sport/NFL/Season 2025/NFL 2025-09-07 Washington Commanders vs New York Giants.mkv /Sport/NFL/Season 2025/NFL 2025-09-09 Chicago Bears vs Minnesota Vikings.mkv this is after the naming that appears on sportsdb: https://www.thesportsdb.com/event/2261202-chicago-bears-vs-minnesota-vikings Potential Filename https://www.thesportsdb.com/images/icons/plex.png NFL 2025-09-09 Chicago Bears vs Minnesota Vikings.mkv https://www.thesportsdb.com/images/icons/kodi.png NFL 2025-09-09 Chicago Bears vs Minnesota Vikings.S2025E1.mkv https://www.thesportsdb.com/images/icons/kodi.png (Scraper) NFL 20250909 Chicago Bears vs Minnesota Vikings.special And what exactly is empty?
EmilD 1 Posted January 20 Author Posted January 20 (edited) My library is set to content type "TV shows" and the metadata is set to SportsDB. But this library is always Empty under Shows or Episodes. the only place i can find the files are under "Folders" Edited January 20 by EmilD
Luke 42251 Posted January 20 Posted January 20 22 minutes ago, EmilD said: My library is set to content type "TV shows" and the metadata is set to SportsDB. But this library is always Empty under Shows or Episodes. the only place i can find the files are under "Folders" Sounds like you still have the folder added into another library with a different content type?
EmilD 1 Posted January 22 Author Posted January 22 On 1/20/2026 at 11:27 PM, Luke said: Sounds like you still have the folder added into another library with a different content type? that did the trick! 1
