tedfroop21 89 Posted September 24, 2025 Posted September 24, 2025 (edited) embyserver.txtembyserver.txtI did some rewiring speakers today and went to check everything was as it should be. Just for the heck of it I tried playing from my Roku. Both of the DTS-MA tracks I selected (including the default DTS-MA track) played other commentary (DD) tracks vs the track they should have played. Played the same file on Android and it works as expected. Very Odd... embyserver.txt The Lord Of The Rings The Fellowship Of The Ring (2001).mkv.MediaInfo.html Edited September 24, 2025 by tedfroop21
ebr 16332 Posted September 24, 2025 Posted September 24, 2025 Hi. This is likely going to come down to how the tracks are tagged. Are there multiple with the "default" tag?
tedfroop21 89 Posted September 24, 2025 Author Posted September 24, 2025 The commentary tracks being played are the Stereo english AC3 tracks
speechles 2062 Posted September 24, 2025 Posted September 24, 2025 @tedfroop21Was there an ffmpeg log created? If you choose "Playback Correction" once or twice does it allow you to correctly choose? 1
rotational467 44 Posted September 25, 2025 Posted September 25, 2025 I know this is not super helpful without logs, but I saw this exact behavior a few weeks ago while on travel with an older model streaming stick (3800 I think) connected to a TV, no surround sound capabilities. Same scenario as OP, the media has a DTS-MA track flagged as default and a second stereo AC3 track (commentary) which is not. I know a single click of Playback Correction did not fix it, I don't think we tried two clicks. Opening the playback menu and manually selecting the DTS-MA track (which was already marked as active) also had no effect. Have not seen this behavior with newer model Rokus on the local network. If I can reproduce will post logs, but wanted to call out that this is not necessarily an issue with multiple tracks flagged as default. @tedfroop21what model Roku device?
tedfroop21 89 Posted September 25, 2025 Author Posted September 25, 2025 My cognitive functions are not great right now so I didn't check. I will tomorrow. I neglected to mention its all direct play, no transcoding, if the log says it was there's a problem. I picked that file as its 6.1 and the back channels were the ones that got new wire. What is odd is that the AC3 stereo tracks were the ones playing when I selected the two DTS tracks, different tracks for each of the English DTS tracks I selected. The Stereo tracks are commentary.
ebr 16332 Posted September 25, 2025 Posted September 25, 2025 Your pic above is not from the Roku app... is this occurring elsewhere as well? In some situations, the Roku will simply not let us change the audio track but we need to see exactly what is going on here. If you look at the tracks in mkvtoolnix, are more than one marked as default?
tedfroop21 89 Posted September 26, 2025 Author Posted September 26, 2025 One default track, as above. Roku Audio settings are Preferred Streaming Format - Auto, Digital Output Format - Passthrough. The problem is only in the Roku app (Web and Android are the others tested)
pwhodges 2033 Posted September 26, 2025 Posted September 26, 2025 That's the normal MKVToolNix layout, so the last column showing must be "default" - but I suspect we also need to see the next column, which will be "forced". Paul
tedfroop21 89 Posted September 26, 2025 Author Posted September 26, 2025 (edited) Just for fun, I threw The Hobbit disk, I notice there are two movie files shown. One is English/Japanese, the other English French. Is it possible we hit a limit for the number of audio tracks somehow? What was odd was the behaviour in playback was the DTS-HD Master played one commentary track, and the DTS-ES track selected played the next commentary track, as though the first four tracks didn't exist. Edited September 26, 2025 by tedfroop21
ebr 16332 Posted September 26, 2025 Posted September 26, 2025 1 hour ago, tedfroop21 said: Is it possible we hit a limit for the number of audio tracks somehow? Yeah, possibly. I doubt the Roku player is designed for tons of audio tracks. In fact, some of the early hardware would only support one. You might try muxing one with just a couple tracks as a test.
tedfroop21 89 Posted September 26, 2025 Author Posted September 26, 2025 5 hours ago, ebr said: Yeah, possibly. I doubt the Roku player is designed for tons of audio tracks. In fact, some of the early hardware would only support one. You might try muxing one with just a couple tracks as a test. Will do, and I will let you know. As sort of a "pre-test" I ran a bunch of files with less than 5 tracks and no problem. I will likely remove the tracks one at a time and see if there's a limit and where that is.
speechles 2062 Posted September 26, 2025 Posted September 26, 2025 (edited) @tedfroop21If you remux the MKV with MKVToolNix it will put all the stuff the Roku wants to see at the front of the file ahead of the streams. That might be all you have to do. The Roku also might not be able to parse them if there are "tags" or "global tags" present in the file. Sometimes the Roku isn't fussy. Sometimes it is. When it is I remove all the global tags. The Roku tends to choke at times if those are placed in odd spots. If the file is built incorrectly the entire file must be downloaded to the Roku before you can change things. The audio track change might work in the last 20 minutes of playback. If the header is built correctly you can change things as the file is being downloaded. You can change them immediately. Edited September 27, 2025 by speechles
tedfroop21 89 Posted September 28, 2025 Author Posted September 28, 2025 On 26/09/2025 at 17:54, speechles said: @tedfroop21If you remux the MKV with MKVToolNix it will put all the stuff the Roku wants to see at the front of the file ahead of the streams. That might be all you have to do. The Roku also might not be able to parse them if there are "tags" or "global tags" present in the file. Sometimes the Roku isn't fussy. Sometimes it is. When it is I remove all the global tags. The Roku tends to choke at times if those are placed in odd spots. Even if it was ripped with Makemkv? Not that it makes a difference but I find it odd...as odd as the fact I have watched that file many times on my Roku without issue. Sorry I have left it at the moment - I have been a little messed up this week..... 1
Solution tedfroop21 89 Posted September 29, 2025 Author Solution Posted September 29, 2025 Sooo, chalk it up to executive dysfunction and lack of sleep (auditory hallucinations suck...). - Went through AVR and TV settings to bake sure nothing changed. - Tried an alternate HDMI cable. - Unplugged the AVR for a few minutes. Plugged it back in. Success. I assume the AVR not having the decoder available was confusing things. Thanks for all your help guys.
ebr 16332 Posted September 29, 2025 Posted September 29, 2025 Wow. Weird. Let us know if you run into it again.
tedfroop21 89 Posted September 30, 2025 Author Posted September 30, 2025 4 hours ago, ebr said: Wow. Weird. Let us know if you run into it again. Yeah, weird is right.....
