hilac 0 Posted September 23, 2025 Posted September 23, 2025 hi! i'm using emby on LG tv. in the emby settings, i've set numbers for the channels (in the edit windows of each channel) but it doesn't work with the LG remote at all... anyway to make it work? thanks!
Luke 42233 Posted September 23, 2025 Posted September 23, 2025 HI, what exactly doesn't work? Can you please describe your issue in more detail? Thanks.
hilac 0 Posted September 23, 2025 Author Posted September 23, 2025 When pressing The numbers - it has no effect. They’re not shown on the screen, and the channel doesn’t change. should I configure something in the lg tv settings? when watching other streaming service- numbers do work
Luke 42233 Posted September 23, 2025 Posted September 23, 2025 OK that's currently not supported but is planned for future updates. Does your remote have channel up/down buttons? That should work.
hilac 0 Posted September 24, 2025 Author Posted September 24, 2025 the remote control does have channel up/down, but it's not working either.. something i need to configure for it work?
Luke 42233 Posted September 24, 2025 Posted September 24, 2025 1 hour ago, hilac said: the remote control does have channel up/down, but it's not working either.. something i need to configure for it work? When exactly are you trying to use it?
hilac 0 Posted September 24, 2025 Author Posted September 24, 2025 When im watching channel x, I try the +- channel button but its doing nothing @SamES
SamES 1084 Posted September 25, 2025 Posted September 25, 2025 @Lukeshould channel up/down work while playing a channel?
Luke 42233 Posted September 25, 2025 Posted September 25, 2025 Just now, SamES said: @Lukeshould channel up/down work while playing a channel? Yes.
SamES 1084 Posted September 25, 2025 Posted September 25, 2025 (edited) 12 hours ago, Luke said: Yes. @LukeChannelUp/ChannelDown on the remote triggers PageUp/PageDown events, not Channel Up/down events. I don't think you can just remap these in a simple way as we still need Page Up/Down for navigating list views. Maybe we can respond to page up/down events as channel buttons during playback. Edit: Forget that, I don't think it's worked that way for while. We just need to respond to PageUp/Down events for channel changes. Edited September 25, 2025 by SamES 2
